H22a5 swap TDC sensor fault code
    Hi guys
    So I swapped h22a5 in my cd7 accord, and I get all the time error 9 and 45 on the ecu. The ecu I'm running is p1j mapped for f20 engine. The harness is the original I just put new plugs for the distributor and alternator and all the colors matched. Has anyone else had this issues?
    P.S the first time I try to start the engine I burned the coil because I was curious if there was spark on the spark plugs... I fitted new coil in the distributor and now everything is ''fine''. The engine runs very well but the ecu thinks something else.
