Hello guys im new to the forum. I own a 90 cb7 coupe that im doing a k24 swap. I am almost done but i see most people remove the power steering but i plan on keeping it, and i already mounted everything including the high pressure hose. My main problem is with the rack. Since the vss is canceled and im running the stock k24 power steering pump and reservoir i currently have two fittings on the rack and pinion that i dont know what to do with. I know the one for the vss can be canceled but i dont know what to do with the other port. Should i T into the one going to the cooler? Any help would be appreciated.
Thanks
Thanks
