Clean Engine Bay
    Clean Engine Bay
    I was wanting to know how to clean my engine on my 91 EX
    Do i pressure wash it?
    visit vgruk
    sure
    Retro!
    Hater
      so do i leave the enging running and just go at it? are there things i should cover?
      visit vgruk
        I'll just leave these here.
        http://www.cb7tuner.com/vbb/showthre...ght=engine+bay
        http://www.cb7tuner.com/vbb/showthre...ht=wash+engine
          thanks! I used the search function but i did not get anything
          visit vgruk
            LOL I wasnt trying to be an ass. I just answered your simple question lol.
            I wanted to feel how it would be to be like a Dick for a day lol.
            Retro!
            Hater
              I found WD40 does wonders on cleaning and shining under the hood.
              Example: http://www.d-series.org/forums/diy-f...-civic-si.html
              -Ian
              '92 EX Coupe (Member's Ride Thread)
              My Blog - Mostly snark about professional motorsports, but I occasionally make it to local and regional events. It's not much now, but I'm working on it.
                Yea, it does an amazing job lol
                  dont pressure wash it ,, its a joke
                  10th Anniversary Accord.
                  05 Audi A4 Ultra Sport 6MT.
                    Why's that?
                    I pressure wash mine with hot water after soaking it with some simple green all the time.
                    Just make sure not to blast it directly at the distributor and any other electrical connections with old/bad seals. I replaced all of my seals and put electric grease in all of my connectors. 0 issues in over 5 years of spraying it down. Proper maintenance is key. I don't keep my engine running ether.
                    MR Thread
                    GhostAccord 2.4L Blog
                    by Chappy, on Flickr
                      At work (Honda dealership) we spray degreaser on when it's cold. Start the engine then pressure wash but moving it quickly so it's not directed at anything then blow all the water off with a compresser and open air attachment
                      #3MR 91 coupe: http://www.cb7tuner.com/vbb/showthread.php?t=186456
                      #2MR 90 sedan: http://www.cb7tuner.com/vbb/showthre...51#post2867651
                      #1MR 93 coupe: http://www.cb7tuner.com/vbb/showthread.php?t=176343
                        what if he has vacuum leaks or loose wires ,, soft and brittle hoses ir plastic ,, everythin in there must be nice and tight.
                        i wouldn't do it to mine because i know i could. brake some stuff
                          Originally posted by GhostAccord View Post
                          Why's that?
                          Does it harm the engine if its running?
                            No, personally I have done it for years. I usually like doing it because if there was a manifold leak and you sprayed water it will change the sound of the motor. If it was off, you wouldnt know and you may flood the engine.
                            Then he should look at that prior to doing the job. It will be his fault. This forum is a forum of help and suggustion, if he has a bunch of fucked up lines and he sprays it....its not our fault =)
                            Why's that?
                            I personally stopped blasting the distribitor. But I usually do a quick pass at it. Sometimes I get water inside. I dont do any electric grease or anything. I even spray the alternator lol.
                            I been pressure washing for years. Toyotas are sensitive to it, so i dont really concentrate on some parts in the engine bay.
                            Retro!
                            Hater
                              Thanks for that information.
