awesome, feels like I offered something here so I'm glad I could help. I hadn't heard the video until now, but as soon as I did I knew the ground was the issue. as you get voltage the valve opens to control boost. you get voltage as pressure builds in the manifold.
when you try and start the car, the valve wants to close (grounds through acc as you turn key to on) but if it's get voltage on ground, it's both trying to open and close hence the noise you were hearing.
glad you figured it out.
soldering tip;
I like the 3m shrink tube w/solder joints built in. well worth the money.
http://m.ebay.com/itm/50-pcs-RED-BLU...-SEAL-NO-CRIMP
soldering tip;
