Euro-r power steering
    I got a power steering pump, bracket,high pressure line from a 93 prelude with a h22 motor out of the junkyard but it want sit flat on the block anyone else have this issue or do I have the wrong pump and bracket being that my motor is euro-r?
    Hey Skeeter. Umm we need more details but it sounds like you have the wrong pump. Just get the part # off the part and make sure it's the correct one for your engine. If you are trying to put a H22 PS Pump on a F22 it will not work.
      or do away with belt driven ps and run a mr2 pump. thats what im using w/ k24.
      COUPE K24
        Curious what you are doing for controlling and powering the MR2 pump?
          its all in one. the pump has a module built in and just 5 wire hookup. ill make a diy soon. it works awesome.
          COUPE K24
            Indeed, I do quite enjoy it as well. Where did you mount yours?
              damn thats badass!! mine is just laid up in the engine bay for now. is that the kmotor bracket? i like that position a lot.
              did you wire in a separate switch? i deleted my cruise control and pinned the mr2 pump the switch out so it looks factory lol.
              COUPE K24
                Mine is wired to the Cruise Switch also. It works really well there.
                Its a bracket a guy on k20a makes (made?). I had to cut off the flange to mount it there.
                  sweet yea, i think its the same one on ebay. i need to get one soon.
                  COUPE K24
                    I have a obd2 h22 euro-r motor and transmission. The power steering came off a 1993 prelude with a h22 auto transmission .
                      Damn, that MR2 ps setup is sick!
                      Skeeter I think you need to use a later ps w/bracket setup. Like 97 & up Preludes have.
                      If I remember correctly my 97 Acura CL with Euro-R set-up used the f22b (97 CL stock motor) ps & bracket bolted to the Euro-R motor.
                      ~Mark~
                        Thanks, I think I seen a few of them out there. High pressure mline and all just like I got off the prelude?
                          That is definitely very nice!! Might have to add that to the list if my other PS idea doesn't work.
                          YouTube Clicky!!
                            Ummm ok i need to know how to do this now There are not a lot of mods left to do on the car to do but I'd love to do this while the engine is out.
                            What do I need to make this happen?
                              Skeeter
                              Yes, chances are you’ll have to use the ps line from the car you get the bracket, pump, etc from. Just make sure the ps bracket has the same mounting bolt pattern as your motor.
                              ~Mark~
