Old 01-15-2014, 04:34 PM   #1
accordbol
Newcomer
accordbol is cool... so far.
Question F22a Swap To F23a
Friends, I could not find a replacement engine for my f22a2 CB7, but I have found the F23a, can I install it? Is it possible? Won't be too difficult?
accordbol is offline   Reply With Quote
Old 01-15-2014, 05:35 PM   #2
Jarrett
Contributing Member
Were you the same person who asked this on the Facebook classifieds thread?
It's possible, and quite easy to a point, but it does have some complications involving ECU compatability in an OBD1 application. The same applies for most swaps that you would do. You'll use your original harness and distributor and just add VTEC wires to the harness. You'll no longer use the CKP harness on the oil pump. You'll need either an OBD1 P0A ECU or a P28 ECU tuned for the application. Use your factory driver side mount bracket and make sure you have a header for the F22B1/2 or F23A and you're good.
That's pretty much it. Had you searched you would have found most of this out.
__________________
Old 01-20-2014, 07:19 PM   #3
zach09
Newcomer
zach09 is cool... so far.
Question
I plan on doing the same swap here soon! i just bought a motor from over seas and has a 1 yr unlimited mile warranty. Got it from a local shop here were i live. I was told to use the following f22 parts:
Intake manifold including throttle body, injectors the whole thing
dizzy
ps pump
alternator
post mount bracket for timing but use a f23 timing belt
and then a header off a f22B motor.
Does this all sound right?
zach09 is offline   Reply With Quote
Old 02-17-2014, 04:23 PM   #4
accordbol
Newcomer
I have managed to connect the F23a block in my F22a, is working to perfection but now I'm having problems with the automatic transmission, you should use the same? The F22A (mine has faults) or can I install the F22B or F23A?
Old 02-17-2014, 04:30 PM   #5
deevergote
Don't call me dude.
deevergote . You'll never be this cool... deevergote . You'll never be this cool... deevergote . You'll never be this cool... deevergote . You'll never be this cool... deevergote . You'll never be this cool... deevergote . You'll never be this cool...
Send a message via AIM to deevergote
Any transmission that came on an F series will work.
__________________
deevergote is offline   Reply With Quote
Old 02-17-2014, 07:32 PM   #6
djscoonf22A6
CB7tuner Member
djscoonf22A6 is cool... so far.
i did this swap i could help u
djscoonf22A6 is offline   Reply With Quote
Tags
f22a , f23a , swap
