Rims...what can fit on our stock 4 bolt
This topic is closed.
    currently rim shopping for used rims that im looking to refinish
    and im wondering if acura el, rsx or civic si or si-r rims would fit on our stock 4bolts without any issue
    as im not really a big "rim" guy im not too familiar with what fits and if certain hubs are drastically different, if anyone knows what rims fit good and can offer some advice that would be great
    Those are 5 lug, the 1999/2000 Si are 4 lug and they don't look good on the CB IMO.
    The Acura RL is 5 Lug.
    Just do a 5 lug conversion, you'll have a better choice of rims for you'r car. If not, you can get the rims re-drilled.
      99/00 civic si wheels don't fit our lug pattern anyways...
      we have LOTS of 4 lug options as seen in this thread.
      http://www.cb7tuner.com/vbb/showthread.php?p=2966884
        But those are OEM, we don't know if wants OEM or aftermarket.
          oem or aftermarket, pretty much any rims that can go on our CB's from another accord, or any other acura/honda for that matter. preferably oem ones as budget is somewhat of a factor and i see lots of honda rims floating around locally
            Just make sure what ever wheels you decide to go with are 4x114.3 lug pattern. A lot of the civic wheels are all 4x100 lug pattern.
            http://www.cb7tuner.com/vbb/showthread.php?t=189897 MRT
            http://www.cb7tuner.com/vbb/showthre...09#post3003309 EF hatch build
              thats exactly the info i was looking for! so basically anything thats not 4x114 wont fit?
                Anything that isn't 4x114.3 is like putting a square peg through a round hole.
                Look for any rim with that lug pattern, and an offset between +38 and +45... more or less can be used, but those offsets should fit with no additional modification.
                  Be aware that some rims, including some other factory Honda rims, may require you to run 5mm spacers on the fronts to clear the calipers.
                  4 bolt Integra Type R wheels (like in my sig pic) and 88-91 Acura Legend teardrop rims are a couple examples that will require such spacers.
                    Do you know the offset of those wheels that require spacers? And do you know the offset of stock alloys (you'd think I would know that by now, but I don't!)
                      My Datsun z wheels are 4x114.3 with a +15 offset and the front wheels NEED spacers to clear the brakes... And a bit of sanding to the brake bracket. I hope no one else used these wheels though
                      My 91 ex coupe
                      http://www.cb7tuner.com/vbb//showthread.php?t=189841
                        Advice= if your looking for factory wheels and wanna step away from the usual Honda, look into older cars. 4X4.5 equals 4x114.3 correct me if I'm wrong.
                        My 91 ex coupe
                          91 ex wheels are a +50
                          But I believe requirement of spacers has less to do with offset and more to do with wheel design and actual back spacing from the spokes <=less then hub
                          My 91 ex coupe
                            Yeah, 114.3mm = 4.5"
                            And you're probably right about the clearance. Some wheels require a spacer because the inner edge is too close and will hit when turning the wheel, but perhaps not the OEM wheels.
                              Since were talking about rim fitments what's a good offset for a nice flush look
