So I need too do a timing belt on my 96 LX and I last used the Continental brand kit on my CB7 when that needed one, so who here has or is using this GMB kit? Anyone think it is too cheap? Anyone had problems with it? How long have these been out? Long enough that if thyey sucked we would by now? Thanks in advance!!
GMB Ebay Timing belt kit opinons
Cool thank you did you find those kits on ebay or somewhere else? I know my continetal kit seemed to work fine and was nice rubber but it also is more exspenive then this GMB kit and the GMB kit comes complete ready too install I also only was able too put like 12000 miles on that continental kit so who knows if it would last 7 years" Insert funny quote here "
Originally posted by spiderpig View PostCool thank you did you find those kits on ebay or somewhere else? I know my continetal kit seemed to work fine and was nice rubber but it also is more exspenive then this GMB kit and the GMB kit comes complete ready too install I also only was able too put like 12000 miles on that continental kit so who knows if it would last 7 years
You can buy quality parts on ebay, but you have to be careful. Be sure that the parts are legitimate. You don't want some cheap Chinese-produced part that was just made to look like an authentic brand name. You don't want a genuine part that has been sitting in a warehouse since 1996.
Honestly, given the fact that the F22A is an interference engine, you'd be wise to use the highest quality timing belt you can find (directly from Honda is never a bad idea.) You'd probably be smart to replace the tensioner while you're at it.
If the tensioner or the belt fails, your engine is toast. A new engine is going to cost far more than a quality belt!
Originally posted by deevergote View PostHonestly, given the fact that the F22A is an interference engine, you'd be wise to use the highest quality timing belt you can find (directly from Honda is never a bad idea.) You'd probably be smart to replace the tensioner while you're at it.
Changing the water pump is always a good idea, agreed. Again, that's another thing that is best purchased from Honda.
In fact, ANYTHING that will destroy the engine very quickly if it fails is something I would get from Honda, unless it's a significant performance upgrade (and in that case, I'd prefer to get known quality brands.)
I see what your saying guys but Honda OEM parts are not very affordable for me and for what I see GMB is made in USA and has some positive reviews also I plan on changing out water pump and tensioner along with all seals and things as well. I cannot believe no one on here has used the GMB kit either on a cb7 or another car Honda parts seemed very overpriced too me" Insert funny quote here "
GMB makes a decent product. Their tensioners and bearings are very good quality usually made in Korea.
The pumps are also good, I have had good experiences.
I also worked for a company that sold a LOT of GMB product, we are talking hundreds of thousands of sales, their warranty rate is VERY low.
I would buy the kit.
What I don't get is Honda isn't actually making these parts they are contracting them out too other companies who are in the belt business so what can be all that different? All have same number of teeth right? All are rubber right? What more can be different then say the quality and construction of the rubber? I mean I am worried that this kit is of a cheaper quality because it is 70 bucks and has so many parts in it as well. I cannot see how OEM is that much better they have so much over head while someone selling their own kits on Ebay have little overhead" Insert funny quote here "
Once the kit arrives, if any of the individual parts are made in China, I might shy away from using that specific component. I would say this applies most to the actual belt itself. If the belt is made in China I wouldnt run it.
The timing belt will probably be Mistuboshi which makes a good belt. Or Continental.
Water pump and tensioner will be GMB. Probably made in Korea both of them.
Do some research on the Honda part, look for the manufacturer that actualy makes the part. Something listed as the brand is much cheaper than Honda and should be the same thing.Be unique, like every other person.
I used a gmb water pump in my z for years. I finally swapped it out but it was still in great condition. 17 years and 75k it lasted.
As for their other parts I have no clueWhat makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
