I know the Acura CL rear sway bar fits the Cb but does v6 3.0 rear sway bar fit to Cb. are they all the same size 14 millimeter I can't find any information on the v6 rear sway bar please help me thank you
rear sway bar...cl
rear sway bar...cl
Mostly Usdm, some Jdm,Edm,&Puerto Rican RICETags: None
If I were you I would look at 94-97 Accord rear sway bar as they are 15mm thick. Or look into a Acura Vigor rear sway bar as they are 16mm thick. Either of those options are direct bolt on, easier to find than a CL.
To answer your question though I don't see why the rear sway bar wouldn't fit from the v6 CL.
After some checking both the 4 cylinder and 6 cylinder both have the same rear sway bar part number 52300-SV4-912.
Awesome thanks man**Blk Housed Slut Crew Member #1**
