So I just bought another 1993 Honda Accord EX and have no problems with it other then this. When started the alternator will whine but yet always keeps a steady charge at 14.7 volts while running. Just put a brand new battery in there for good measure as I didn't know how old the cheapie battery was that came with the car. My question is why would it whine like this when its giving a full charge? The lights and when everything is on its all as bright as can be.
Alternator problems 1993 Honda Accord EX
could be the pulley bearingsWife: "Why do you get G power platinum and i only get V power?"
Me:"Cause i have the high compression 93 octane only H22 and you have the bullet proof F22."
Wife:........................"But yours are prettier"
Wife:Baby, not everybody wants to do the 93 conversion"
Me:YES THEY DO, THEY JUST DON'T KNOW IT YET.
Bad bearings would cause the alternator to make noise even if its still putting out a charge.
Could be just worn out, or maybe the belt was adjusted too tight (which will put extra load on bearings).1992 EX, 306,000 miles - Track toy - M2S4, H23A1, ST rear swaybar, Wagon brakes, GC coil sleeves, KYB AGX dampers, Stoptech pads, Toyo Proxes R1R, 2.25" exhaust
Stock F22A6
VIR, 5/22/2016: https://youtu.be/eR5-ylSPsxk
H23A1 powered
NCCAR, 9/4/2016: https://www.youtube.com/watch?v=TI5WpxGrEpE
CMP, 10/16/2016: https://youtu.be/DOqoe5f-GLY
Thank you for your help everyone. I changed out the alternator with a brand new not reman Denso unit. Started up the car no whine at all for the first 30 minutes then after driving for a while the same whine came back. Brand new alternator and battery. What could this be? Maybe a ground issue?
Beltsold! But here's my build thread for those interested.
http://www.cb7tuner.com/vbb/showthread.php?t=206864
Originally posted by Kev1990 View PostThank you for your help everyone. I changed out the alternator with a brand new not reman Denso unit. Started up the car no whine at all for the first 30 minutes then after driving for a while the same whine came back. Brand new alternator and battery. What could this be? Maybe a ground issue?
I would have just replaced the belts while I had the whole thing apart. It makes sense since the belts are cheap and easy to replace.
I agree with lbus9168, definitely try replacing the belt.
