Will larger intake help with stock engine? A6 mani
    I want to swap to a6 cam, intake and ecu with h23 plenum and TB.but I’m not ready to swap the cam just yet.I have another set of iab valves for the dual runners though and was thinking that I could just hit the butterfly valves and grind the holes out and run both set of runners all the time. I have intake and full exhaust kit so do you think it would benefit nicely or would it almost bottleneckit? Thanks for the opinions.
    If you eliminate the IAB system, you run the risk of having a soggy bottom end. The h23 plenum should be sufficient, along with the functional IAB, to give a decent bump in power. It’ll get better with the A6 cam, but it’ll work without.
      It’ll get better with the A6 cam, but it’ll work without.[/QUOTE]
      My only worry is that it will run rich because the fuel mapping is of the ecu is different due to larger cam lobes. But I really don’t know how much different it is
        It will likely run a bit rich, but the lobes on the a6 cam aren’t that much more extreme.
        Don’t forget, your o2 sensor will provide feedback, and the ecu will adjust accordingly.
          i ran the h23 intake manifold with double stack plenium but had the IABS hooked up and it made nice low end torque improvements.
          I didn't do the cam but I did the h23 ECU and that helped as well. Felt fun to drive it again.
            Thanks for the feedback everyone, I’ll probably just go for it without the cam for now. Are stock injectors able to tune themselves from the ecu? I wasn’t sure if they could even on a small scale
              The injectors are the same on all f22a engines, as well as the h23a1. That won’t be an issue.
