Rescuing Ruby, Extensive Quarter Panel Rust Repair
    Back at it. Got the wheel housing welded in Saturday. Got some trimming done today preparing for quarter skin installation.
      major props on your project! Been following along..and wow you do an excellent and proper job, cant wait to see it done and what youll do after the shell is A1+.. ^5
        wow impressive job my friend, you make this right, i love the way you turn this car man. great job, keep going, excellent job so far.
          Thank you
          I'm gonna be using this thread for reference some day for sure. My car cancer isn't as bad but it'll have to go under the knife soon enough...
          BB6->http://cb7tuner.com/vbb/showthread.php?t=200445<Summer Lover
          BD6->http://cb7tuner.com/vbb/showthread.php?t=194262<Dailey/Future AutoX
          Mazda 6s->http://cb7tuner.com/vbb/showthread.php?t=201313<Wifes
          CB7->http://cb7tuner.com/vbb/showthread.php?t=189108<Sold
            Major talent going on here ..
            Originally posted by fleetw00d View Post
            Driver side opened up.
            You Sir, (after it's all said and done) shall receive The CB7 Tuner Award for an achievement that recognizes the most dedicated, passionate, and devoted member!
            Atleast in terms of body restoration ... WoW!
            I'm pulling up a chair and grabbing some pop-corn, this is gonna be sooo awesome!
              First rough trial fit of the quarter skin. Still need to trim for butt welds at the C pillar and rocker, make weld backing plates for those two welds, and clean up and apply rust preventative coating to the inside of the quarter panel and all surfaces of the wheel housing. I'm doing the rear corner a bit different than the right side, just a bit of overlap at the corner instead of several inches in from the corner I did on the right (the corner seam was rusted). This side looks like it will line up better with the door.
              This is one of those days I wonder why I'm doing this. I found a 93 EX sedan auto with only 71,000 miles in Dayton and a 93 EX sedan 5 spd in Waynesville with only 92,000.
                Yeah i know but you are keeping ruby alive and not letting her rot in the junkyard.
                BTW the progress is amazing. It gives me so much motivation if/when (betsy) rots out.
                Can't wait to her back on the road.
                  Made the cuts for the butt weld joints at the C pillar and rocker. Cut weld backer plates from the scrap peices; still need to strip them and tack them in place. Need a little more work at the rear corner to get it to line up a bit better and get the trunk gap a bit narrower.
                    I got to give it to you man this is one hell of a proect. Badass and very inspiring at the same time. Keep it up bro
                    http://www.cb7tuner.com/vbb/showthread.php?t=189897 MRT
                    http://www.cb7tuner.com/vbb/showthre...09#post3003309 EF hatch build
                      Made A LOT of progress over the weekend. Did final trimming of skin and body, installed backer plates for butt welds at C pillar and rocker, then applied adhesive to the wheel well joint and where the quarter meets the trunk floor on Saturday. Let that dry overnight, then welded the door jamb, rocker along the bottom, rear window opening, and rear corner. Door and trunk gaps turned out very well. The trunk lid itself sits slightly high at the left rear corner, not sure why at the moment.
                      Clamped after applying adhesive .......................................... Welded window joint
                      Yesterday I went over all the area that will be hidden by the bumper with a wire brush, cleaned it with brake cleaner, applied rust conversion to a few spots with a little surface rust, then applied Eastwood Rust Encapsulator over the entire area. I still have to fashion one patch plate for the end of the rocker box section in the wheel well (I must have thrown the piece from the donor quarter out with some other scrap metal). (Update 1/12/2013 - oh well, while trying to consolidate all the parts from the wreck, I found the piece I thought I threw out.) I'll use the adhesive to install this piece.
                      Next I'll get it to the shop to complete the butt welds at the C pillar and rocker. Then figure out how much of the paint job I want to try to tackle.
                      Added July 21:
                      Had the butt joints welded. Now I need to strip off all the trim before paint.
                        nice work my hats off to you sir . shes comeing along perty good ive been reading through your hole thread from the start and you have made some dam good progres . hats off man hats off.
                        this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
                        Car safety checks
                        Fluid Capacities
                          OMG! Folks, this man KNOWS whats up with sheet-metal!
                          Fleetwood .. you are one talented individual .. that looks simply amazing.
                          I've only known one other person who could do this kind of work.
                          A friend of mine had a shop in Costa Mesa, and he got a Porshe 911 that got sand-witched.
                          Literally, it looked like an accordian. It may have taken him a year and 10 months,
                          but he not only brought it back to life, he actually turned it into a 930 turbo!
                          Blew minds! An amazing talent, and a huuuge amount of passion! Major props!
                            wow great work here
                            Lou's Build Thread!
                            http://www.cb7tuner.com/vbb/showthread.php?t=181377
                            "G-Squares Are For Assholes"~PR_CB7
                              Great work my friend. I'm still looking for 1/4 panels for my wagon, I wish to repair mine as I've had it for almost 9 years now.
                              1992 Accord Wagon (RETIRED)
                                Trying to get ready for paint. Unfortunately found a few more rusted areas up front. Pulled off the front bumper, grille, headlghts, windshield trim, door mouldings, door chrome, chrome above the windows, door handles (how does the handle housing bend down so that the handle touches it and rubs off the paint?).
                                Treated this side with rust conversion, probably fill with body adhesive.
                                May have the body shop deal with this.
