Thread Tools Rating: Thread Rating: 50 votes, 4.70 average. Display Modes
Old 09-29-2019, 07:29 AM   #2561
Raf99
Gold Member
Quote:
Originally Posted by sonikaccord View Post
What's Sally running in the quarter?
No idea. Never been to a drag strip. I'm hesitant to go as I would need to drive her there, abuse her and then drive home. (No truck and trailer). Technically I could have someone time me while in the car I guess....?
Old 09-29-2019, 11:54 AM   #2562
sonikaccord
Contributing Member
sonikaccord seems to have made some friends!
I'm pretty sure an app would work
__________________
YouTube Clicky!!
sonikaccord is offline   Reply With Quote
Old 09-29-2019, 05:04 PM   #2563
Raf99
Gold Member
Well....... now you have me excited....
Old 10-21-2019, 05:59 PM   #2564
Raf99
Gold Member
Ya.. i didn't get a chance to try that out yet. That time of the year, by the time I get home traffic is horrible and it's almost dark. Hopefully this weekend I'll have time. I did decide there are some hacks I still want to do and things I want to repair..
- install the rad upper braided hose
- install the LED light switches
- level the spoiler and fix paint spots around the car
.... pic i took today...
Old 10-25-2019, 02:10 PM   #2565
Raf99
Gold Member
Replaced the PS pump today. Straight forward and fixed the issue...
The old
Compare parts. In this case the outlet was smaller diameter. Meh..
Fini
& for Sonic! Just left the app running and did two pulls when no-one around on the road. Guess this is the best of them. Was spinning 1st and 2nd for sure, i was throttling it at high rpms, WOT in 3rd. I'm assuming it's semi-accurate..
Old 10-26-2019, 08:32 AM   #2566
G. Wiffington
CB7tuner Member
G. Wiffington seems to have made some friends! G. Wiffington seems to have made some friends!
Quote:
Originally Posted by Raf99 View Post
Weeeellll..... I fixed the battery and went for a cruise and ... i still have an issue. & I ... don't know the answer. Man this errks me when I can't figure stuff out.
Here's 3300rpm, 55mph, 4th gear, cruising.... @ 16.6+ A/F
Been lean & mean since I got it back. .....
Hey! this is the fuel change setting I was talking about.
You can see where all that red/yellow/orange area was with a positive
percentage number was indicating you needed a little bit of fuel in that
area. If you look towards the bottom right corner of the map you can see
negative percentage numbers, which means fuel could be pulled if you want.
Glad you guys figured out the lean issue on cruising.
__________________
Keep Pushing..
G. Wiffington is offline   Reply With Quote
Old 10-26-2019, 06:09 PM   #2567
Raf99
Gold Member
Re-visiting this final engine bay modification, the upper braided rad hose. After 4 alterations..... what do you think?
Will cut it at the black line...
final product...
Slight grade..... enough?
If this will flow, and works. Then this will be the final product. But... will the two 90deg. cause a flow issue, not sure. Also I need to make a bracket that holds the line up off the lower rad hose.
Old 10-27-2019, 01:33 PM   #2568
djALBINI
Gold Member
djALBINI is cool... so far.
braided rad hoses look super clean!
Read about slipping tires on dyno...
PFIspeed uses spray adhesive AKA "dyno sauce"
This eliminates tire slippage on high HP vehicles even with smaller tires
Hope this helps some
Keep on keepin on
djALBINI is offline   Reply With Quote
Old 10-27-2019, 04:28 PM   #2569
Rilas
Gold Member
Keep on keepin on
If I understand it correctly dyno sauce is pretty much hair spray. Makes the rollers and the tires stickier therefore less slippage. I'm not 100% sure though but the little bit I've looked into points in this direction.
__________________
Old 10-27-2019, 04:30 PM   #2570
Rilas
Gold Member
Raf the radiator hoses look fantastic now! Glad you finally found an iteration that worked like it should.
I'm glad I randomly found a video of a very similar hose to give you the idea.
__________________
Old 10-27-2019, 04:54 PM   #2571
Raf99
Gold Member
Thanks man!
I shortened the upper radiator hose. Going to give this some thought before I commit to it.
Old 10-28-2019, 04:43 PM   #2572
Raf99
Gold Member
Ya, if it were not for you I may not be here with this rad hose.
So spoke to the tuner and some car folks I know, they all agree. May limit coolant flow a tiny bit but it should work. Only one way to tell......
Old 10-28-2019, 08:21 PM   #2573
H311RA151N
Silver Member
H311RA151N seems to have made some friends! H311RA151N seems to have made some friends!
I like the look. I'm probably missing a more important purpose but why 90's as opposed to 45's?
__________________
Find me on YouTube
https://www.youtube.com/channel/UCx7...BeHuX87LzYChKA
H311RA151N is offline   Reply With Quote
Old 10-29-2019, 03:50 AM   #2574
Raf99
Gold Member
Quote:
The hose would not bend anymore than this, so with 45's it was just not happening. Also the 45deg. ones I cannot find in this color or inside diameter.
I'm not really liking the look of it, but I'll at least see if it's functional.
Old 10-29-2019, 01:58 PM   #2575
H311RA151N
Silver Member
Oic. Looks good though. I really like the idea. I really like that PS pump too!
__________________
Find me on YouTube
Old 10-30-2019, 04:17 AM   #2576
Raf99
Gold Member
Well it's functional at idle and if it works for a test drive then I'm calling this engine bay complete! I may add a turbo blanket in the future but not much else.
To think that I started working on this turbo build 9 years ago.... wow.
Old 10-30-2019, 04:34 PM   #2577
djALBINI
Gold Member
dyno sauce they use is 3m spray adhesive on the dyno
Old 10-31-2019, 10:20 AM   #2578
NSCB15
CB7tuner Member
NSCB15 is cool... so far.
You must've boughten like 10 sets of these now lol
NSCB15 is offline   Reply With Quote
Old 10-31-2019, 11:40 AM   #2579
cp[mike]
ŻŻŻŻŻŻŻŻŻŻŻŻŻŻ
cp[mike] is very helpful cp[mike] is very helpful cp[mike] is very helpful
man that looks really great. you took your time but dang it turned out nice! I like that the plumbing is out of the way so you can see the smoothed bay.
looks like you figured out a good option for that upper radiator hose, too. everything fits nicely and looks so fresh!
youll want a turbo blanket once eventually the housing starts getting surface rusty...
__________________
cp[mike] is offline   Reply With Quote
Old 10-31-2019, 03:53 PM   #2580
Straight Success
Contributing Member
Straight Success is someone to admire Straight Success is someone to admire Straight Success is someone to admire
Just letting you know I'm still peeking my head to follo what's going on. Keep up the inspiration.
__________________
The Lord watches over me!
"...they did the bowties, I did the ascots, as much as I have, I'm still reppin' the have nots..."
- So Raspy
Straight Success is offline   Reply With Quote
