Old 10-01-2019, 08:36 PM   #1
akmcb7
akmcb7 is cool... so far.
Question 5 lug conversion from 4 lug drum to 5 lug drum clicking when brake applied
Converted the rear to 5 lug drum set up driver side is fine no noises right side makes loud clicking varying on speed when brake is applied . pulled the drum back off to make sure no springs where loose cleaned everything up re adjusted the shoes . Can't figure the issue out . Got all new hardware and shoes going to replace everything .
Has anyone had this issue before ?
akmcb7 is offline   Reply With Quote
Old 10-02-2019, 11:24 AM   #2
Raf99
No...
Not a rock or nail in your tire is it ?
Old 10-02-2019, 01:55 PM   #3
akmcb7
Naw man you feel it in the suspension ,been a tech over 10 years and this one got me
Old 01-20-2020, 09:42 PM   #4
underPSI
underPSI is cool... so far.
I've had a similar experience on drum brakes albeit not a Honda when the slack adjusters weren't properly setup.
underPSI is offline   Reply With Quote
5 lug conversion , drum brakes , noises
