Old 10-18-2019, 06:08 PM   #1
zedjr10
zedjr10 may have said something they shouldn't have...
Remy, Bosch or Denso Alternator
I ordered a reman denso alternator from carid and i swear it isn't reman by denso. Came from their warehouse in arizona in an open box and not even cleaned that well. It doesnt hold volts above 12 at idle alot of times. It is jsut draining my dam battery. AM i wrong or something. Aren't quality alternators suppose to hold above 13 volts. Am thinking of just ordering a new remy, reman remy or a bosch. Anyone got a remy or boasch alternator? If so , how is it? Does it hold volts well at idle?
Old 10-18-2019, 06:22 PM   #2
fleetw00d
Not sure what brand I have, but I'm pretty sure they run 14+ at idle. Are you checking at the battery or at the alternator. Make sure all your power cables and battery grounds are in good condition; I bought a CB7 with a battery charging problem - it barely got 12 at the battery but showed 14+ at the alternator. The negative battery cable connection to the transmission housing was bad; threads were stripped. Recently my 92 EX coupe had a badly frayed negative battery cable at the bottom end that was causing slow starts.
90 LX 4dr 5 spd 385,000 - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
07 Element EX AWD 191,000 - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=210623
07 Element EX AWD AT (2) 87,000 - MRT: www.cb7tuner.com/vbb/showthread.php?t=211920
LOTS of CB7 parts - ENTIRE COLLECTION - FREE
Come and get it.
http://www.cb7tuner.com/vbb/showthread.php?t=192583 or watch for banner ad at upper right
Old 10-18-2019, 06:27 PM   #3
zedjr10
Originally Posted by fleetw00d View Post
Not sure what brand I have, but I'm pretty sure they run 14+ at idle. Are you checking at the battery or at the alternator. Make sure all your power cables and battery grounds are in good condition; I bought one with a battery charging problem - it barely got 12 at the battery but showed 14+ at the alternator. The negative battery cable connection to the transmission housing was bad; threads were stripped. Recently my 92 EX coupe had a badly frayed negative battery cable at the bottom end that was causing slow starts.
I guess i will need to check at alternator to make sure. I will first check the connection at tranny. I checked the negative cable to tranny and it looks good. Old but all one piece. The other cables look ok also. I can't imagine it is one of the other small grounds. Grrrr. This is so annoying.So pissed at CARID sending me this fake crap or at least what i believe today is fake crap.
My Honda shop manual has a complex alternator test procedure i don't quite understand. Is there a simpler process for testing these alternators?
Old 10-18-2019, 06:43 PM   #4
fleetw00d
Check the positive cables and connections as well.
Old 10-18-2019, 07:57 PM   #5
zedjr10
Should i check the posi going to the passengers side fuse box and maybe just take all those apart and clean them. I guess i should also check the negative coming from alternator itself also.
Old 10-18-2019, 09:18 PM   #6
fleetw00d
Can't hurt to check them all - easier than changing the alternator again. My last project car also had starting problems early on because the starter was loose on the transmission!
Old 10-18-2019, 09:28 PM   #7
zedjr10
i only drove a couple miles and my battery light cuts on sometimes. Annoying. This is with all accesories on though so i will be ok till i figure this shit out. I was thinking it was a ground but this alt seems to perform worse than the one i took out. Am gong to clean my contacts in the passengers side fuse box also.
SO any opinion on alternators.Reman Bosch, Reman Remy, New Remy or Reman Denso. AM goign to return this supposed reman denso and get something else. FUCK CARID. Anyone
Old 10-18-2019, 09:43 PM   #8
fleetw00d
Sorry, can't offer an opinion on brand; I haven't bought a new one in a long time. The one that failed in my wagon I replaced with the OEM one from the car my daughter wrecked in October last year.
Old 10-19-2019, 01:51 AM   #9
zedjr10
Ok so i cleaned both battery terminals and both grounds on passenger side of car near battery. Also both leads going into the passengers fuse-box and the 80 amp fuse connections. The ground wire going to tranny is intact but greasy. The wires are sort of spread apart and not tightly woven. But all intact.I cleaned all this using electronic cleaner and steel wool. I used wire brushes and rifle wire brushes on all other leads.
All this and still same thing but different with this new alternator. The voltage will sometimes drop when something needs juice and not go up for maybe 10 seconds but other times be fine. At idle it can be fine at 13.7 sometimes with everything on. Old alternator would always drop and stay there. New one only sometimes and usually but not always come back up to proper voltage in a few seconds. In my mind all this points to voltage regulator in alternator. IMO if it was bad wires and lead connections it would not be acting this way. Who knows as i am no electric expert and this is a wild guess.
Also i noticed a plastic plug in passengers fuse box with 3 or 4 really small wires. Like 22 gauge or something. It looks like a short that burnt the edge of plug but have no ideal what these wires goes to. It is on the edge of passengers fuse box closest to the front of car.
I am thinking this reman Denso has crap voltage regulator in it. I guess i need to test the alternator next. Will have to look that shit up as shop manual is confusing.
Also what is the big 3. I have seen it mentioned on here a lot but not in detail. I assume one is replacing negative and positive battery cables. What is other(s)?
All these readings are coming from my interior voltmeter gauge . I haven't tested alternator yet. Will tomorrow or Sunday. Need to look that itzap up.
Old 10-19-2019, 12:04 PM   #10
fleetw00d
Get a digital voltmeter/multimeter to check voltage directly at the battery and alternator (and anywhere else).
Old 10-19-2019, 08:37 PM   #11
zedjr10
What is the big three. Change Battery Cables and what else? What is a good brand cable?
Old 10-19-2019, 10:30 PM   #12
sonikaccord
Big three is:
Engine block to chassis ground
Battery to chassis ground
Alternator to battery positive
Also, any good copper 4 awg cable will work. Do not use CCA (copper clad aluminium) wire!
YouTube Clicky!!
Old 10-20-2019, 12:05 AM   #13
zedjr10
Originally Posted by sonikaccord View Post
Big three is:
IS the oem cable 4 awg. Where approximately is the engine to chassis ground cable?
Old 10-20-2019, 01:33 PM   #14
fleetw00d
Big three is:
Battery to engine (transmission housing) ground maybe instead of "Engine block to chassis ground"? Is there a large cable from the block to the chassis? I know there is a small one from the valve cover and power steering bracket over to the engine mount area.
The battery to chassis ground is a branch of the negative battery cable that bolts to the body right next to the battery.
Old 10-20-2019, 01:58 PM   #15
zedjr10
I was wondering the same thing if there was a bigger ground wire from tranny or engine block to chassis. I see on some models there were but on 92 i don't see anything like that. On 92 that skinny wire from valve cover to ps bracket seems to be the equivalent.
I am also wondering why the 16 gauge wire runs to ps pump bracket then thicker 10 gauge or so goes to chassis. Shouldn't the thicker gauge wire be running from valve cover first? I doubt this is causing my alt problems but couldn't understand the reasoning for that wire configuration.
Now that i know the vibration in car is accompanied by voltage drop in my system. What the heck causes the vibration. It isn't like the rpms drop and then it vibrates. Is some electrical sensor or something not working right cause of less voltage than 12.6 it needs and causing misfires or something. This would explain my horrible city gas mileage. Or is the alternator reaching some point where it's force resistance is too great. Which also might explain horrible gas mileage in city with a perfectly running engine.
I still haven't checked volts from alternator yet. Got to read some tutorials. It seems easy but first time for me and my manual is hella confusing.
Also am wondering if my engine wire harness has a ground? Wouldn't that be the same as alternator ground?
Old 10-21-2019, 03:49 PM   #16
sonikaccord
Engine block is generic term in the Big 3's case. You can replace the transmission wire (the starter grounds through the transmission case), or add a wire to the actual engine block (alternator grounds through the engine block, or both if you are into overkill.
OP:
Yes your wiring harness has several grounds, typically, but they are connected through the chassis ground. Alternator grounds through the engine block/transmission ground.
Technically, the voltage at the battery *should* be the voltage from the alternator. But if you want to measure directly at the alt, you would put the black probe on the alternator case and red probe on the alternator output terminal. Then for a sanity check, I would put my black probe on the battery negative, check voltage, then black probe to somewhere on the chassis to make sure no large voltage differences are present between the three measurements.
At worst, the alternator (assuming 100 amp alternator), might put a load of about 1500 watts, which is around 2 hp, on the engine. That would be at full output, which rarely happens on stock electrical accessories.
The valve cover is isolated from the block through rubber gaskets and gromets. The little wire is simply there to keep the cover from collecting a charge. The larger wire may be for alternator ground, but I don't remember. I'd have to Google a pic lol.
YouTube Clicky!!
Old 10-21-2019, 03:52 PM   #17
sonikaccord
I think it may be around 4-6awg. Nothing more is necessary unless you have high demand accessories like an audio system or performance radiator fans.
YouTube Clicky!!
Old 10-21-2019, 09:59 PM   #18
zedjr10
OP:
Thanks. A lot of useful info. I tested the alternator today at alt. Pretty simple test. I don't know why i was so confused at first. Voltage is 12.2 at idle with all accessories on, ac on and high beams. 12.8 volts with ac button off with all accessories on. I can't test amperage. I don't have an amp clamp. So i guess it is my reman denso alt. I think i am going to get a new remy. I would get a new denso but not available and a bosch has 6 grooves in its pulley adn don't want to deal with that. Remy is oem toyota right. So am figuring it must be good.
oh yeah, negative grounds are all cleaned and cable ground to tranny is in great shape. So must be alternator right?
Old 10-23-2019, 05:27 PM   #19
zedjr10
For future people. The alternators available for these cars have changed alot in last 8 years. Even denso no longer does the remans for these alternators alot of times it seems. AC Delco is Remy as far as alts go. Am not sure if bosch does all the remans in house. I found it on denso site in small print somewhere. I use to think they remand all the stuff in house. So basically who effn knows what you are really getting. Best to just start getting new ones and not rebuilt imo. So off to find a new boasch that will work. Never thought i would put a bosch product on this car after my experience with their o2 sensor. But germany makes some good shit for this car i have found out compared to aftermarket new stuff.
Old 10-24-2019, 07:36 PM   #20
toycar
toycar is very helpful toycar is very helpful toycar is very helpful
Bosche is super high quality
Went through the same stuff with my civic on the alternators. Denso, fine print about them not doing the work and all
O2 sensor issue is isolated
Id trust bosche
Originally Posted by wed3k View Post
toycar is offline   Reply With Quote
