Old 10-25-2017, 08:23 PM   #1
BreckAConner
CB7tuner Member
BreckAConner is cool... so far.
F22A1 Firing on 2 Cylinders
Good Evening,
I wasn't sure where to post this topic, if it's not in the correct spot just delete this post. I have a F22A1 in a 97 Honda Odyssey. It's almost like looking at a CB7 under the hood. I am running a OBD1 PT6 ECU and I'm having trouble with either the injectors or distributor. I'll try to be brief and let you know what the problem is, and I'll list everything that has been modified.
Problem: Looking at the F, the left 2 cylinders 1 & 2 fire, 3 and 4 don't fire. If I unplug cylinder 1, cylinder 3 and 4 start to fire (2 not affected). If I plug back in cylinder 1, 3 and 4 stop firing (2 not affected). If I unplug 2, only cylinder 1 is firing only. It's either cylinder 1 spark or fuel injector/wiring.
I have 180 compression on all 4 cylinders. I rebuilt the motor with stock internals. I've tried timing, (distributor and cam) I've tried rewiring my harness, and checking grounds. I just can't figure this weird problem out. I have no codes on the ECU (tried 3 different ecus), I have went through and fixed every code I had.
Modified Parts:
F22a6 Cam
F22a6 intake
H22a4 Plenum
H22a4 Fuel Rail
F22a injectors
F22a Fuel Pressure Regulator
Milled Head (not sure how much)
Custom wire harness (self built)
Deleted ABS (not sure if matters)
Deleted SRS (not sure if matters)
If you would like to see video, I can record and post a video of this problem if that helps with diagnosing.
BreckAConner is offline   Reply With Quote
Old 10-25-2017, 09:55 PM   #2
wtfisafleek
CB7tuner Member
Sounds like an ignition problem. What distributor are you using? Did you make custom spark plug wires? I wonder if you wiggling the wires back and forth when you take them in and out is shorting them out. Just to be clear, I think when looking at the motor from the front of the vehicle the cylinders are, from L to R: 4 - 3 - 2 - 1.
Does the inside of the distributor cap look ok? Shouldn't be cracked or burned up looking inside.
If that doesn't shed any light on it, you might drop in to ericthecarguy.com and ask over there (no connection to him, I just appreciate his vids and have studied them). He's made some really good videos on old Honda ignitions and seems to know them really well.
Old 10-25-2017, 10:10 PM   #3
BreckAConner
CB7tuner Member
New NGK plugs and wires, it's a 90/91 accord distrubor (coil inside). I've tried different plugs, different distributors, different injectors. Even tried wiring up different wires for the dizzy and injectors and bypassed the harness.
Old 10-25-2017, 10:21 PM   #4
wtfisafleek
CB7tuner Member
The rotor in the distributor should only fit one way if I'm not mistaken, so that can't be it... with you swapping all those parts maybe that rules them out.
Has this motor ever ran correctly with the harness you made?
Old 10-25-2017, 11:32 PM   #5
BreckAConner
CB7tuner Member
Nop, it ran back in the day when it was in my previous CB that ended up getting totaled. Different harness of corse. I've been doing some reading, I'm thinking it's a ground issue. I'm going to keep poking around with the grounds.
Old 10-30-2017, 10:50 PM   #6
GTRON
CB7tuner Member
GTRON is cool... so far.
Quote:
I know when I didn't have my thermostat ground connected properly, my car wouldn't start at all! Freaked me out, the car cranked, but there was no fuel or spark.
__________________
I'm faster then a prius
GTRON is offline   Reply With Quote
Old 11-05-2017, 03:18 PM   #7
BreckAConner
CB7tuner Member
Quote:
Well I found out it's not a ground issue, I think it's interference with the signal wire on the distributor.
Old 11-05-2017, 03:29 PM   #8
GTRON
CB7tuner Member
Glad you're figuring it out, let me know if you need an extra hand.
__________________
Old 11-05-2017, 04:29 PM   #9
sonikaccord
Contributing Member
sonikaccord seems to have made some friends!
Good Evening,
Firing order is 1-3-4-2 for Honda's. In your case cylinders 3 and 4 are causing some issues.
Your custom harness... are the CYP/TDC/CKP wires shielded properly? Are the polarities right? Are they twisted pairs? Do you have a noid light to check your injector firing order?
__________________
sonikaccord is offline   Reply With Quote
Old 04-21-2018, 12:28 AM   #10
BreckAConner
CB7tuner Member
After my custom wire harness, I couldn't get the motor firing right. I put a OEM OBD1 Odyssey harness in the car, didn't make a difference on firing. Before I start tearing this motor down to pieces to figure out what it could be I had a question about the cam. Currently in the motor is a F22B6 cam in a F22A head. I was told the A6 and B6 cam is the same pretty much, if that's true great. The old F22B6 motor was overheated bad... I used the F22B6 from the warped head in the F22A head. Can a cam get damaged from a warped head to make a noticeable difference in firing or can the cam warp as well? I'm about to take a F22A6 cam and stick that sucker inside and see if it makes a difference.
Old 04-21-2018, 12:48 AM   #11
92smokeaccord
CB7tuner Member
92smokeaccord seems to have made some friends! 92smokeaccord seems to have made some friends!
If I am not mistaken I do t think you can use the pt6 ecu. If you do I think you still have to swap a couple pins around on the body to get it to run. You should try a stock 97oddy ecu for the 4 cylinder. It should run fine. Also everything should be used from the f22b motor. Dizzy,injectors, injector resistor( if it uses one) even stock oddy engine harness. The ecu may run the motor a tad bit weird but still on all 4 cylinders.
__________________
my new turbo build
92smokeaccord is offline   Reply With Quote
Old 04-24-2018, 08:25 PM   #12
BreckAConner
CB7tuner Member
Results:
Not sure if the head gasket caused this or what, any ideas?
Old 05-22-2018, 10:40 PM   #13
BreckAConner
CB7tuner Member
I had the block and the head decked/milled, do you think firing on 2 cylinders is because of the timing being way off? The 2 clean cylinders are the ones not firing. I have an adjustable cam gear so I can adjust the timing, but I don't know how much the timing would be off if that's the case.
Old 05-24-2018, 12:29 PM   #14
fleetw00d
Contributing Member
Your initial description says 3 and 4 fire is you disconnect #1- this would seem to be a wiring issue, not cam timing or head gasket related.
__________________
90 LX 4dr 5 spd 376,000 - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
93 LX wagon auto 254,000 - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=208490
92 EX coupe auto 171,151 - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=205114 RIP
92 EX coupe auto 190,000 - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=210341
07 Element EX AWD 176,000 - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=210623
LOTS of CB7 parts for sale http://www.cb7tuner.com/vbb/showthread.php?t=192583 or watch for banner ad at upper right
Old 08-20-2018, 10:17 PM   #15
BreckAConner
CB7tuner Member
Is it possible to have a bad fuel pump but have steady pressure? I checked the fuel pressure and it was 35 PSI and would raise under acceleration. I dropped another motor in to see if the motor I built was the problem. Problem still persists.
Old 08-21-2018, 12:26 PM   #16
sonikaccord
Contributing Member
Fuel pumps can "soft" fail, but you'll typically see pressure decrease as more volume is requested from the the injectors when that happens.
This is important. I would revisit this before you waste time any more time chasing something else...
__________________
Old 08-21-2018, 03:29 PM   #17
BreckAConner
CB7tuner Member
I've got a stock OBD1 ody harness for engine and dash. It did the same thing as the old custom harness I had. I think I have a fuel problem some where. I've changed:
Dizzy
Wires
Plugs
Injectors
Sensors
Relays
Harness
Fuse Panels
ECUs
Motor(s)
I swear, when it comes to something I desire most I have the biggest issues with it. Computers, Cars, House, women, ect.. it's my luck.
Old 08-21-2018, 05:29 PM   #18
sonikaccord
Contributing Member
Nah, just means you have to work a bit harder at it! If you really desire it, you'll get it.
Now, back to this issue.
97 Honda Odyssey with F22A1 and PT6 ECU
Cyl #3 and #4 fire when all are connected.
Unplug Cyl #4 and cyl #1, #2, and #3 start to fire.
You put an OEM OBD1 Odyssey harness in the car, didn't make a difference on firing. The chassis is OBDII. This doesn't have any shock tower connectors does it? The OBD1 engine harness connects straight to the ECU?
It sounds like a signal/timing(not mechanical timing) issue rather than fuel or spark.
__________________
Old 08-21-2018, 09:22 PM   #19
BreckAConner
CB7tuner Member
I was wondering that too if it was the signal with say the dizzy and injectors but I don't get any codes besides 41. With code 41 it wouldn't go away with the o2 plugged in so it makes me believe somethings not right. It's a new NTK sensor.
Old 08-22-2018, 01:18 PM   #20
BreckAConner
CB7tuner Member
I wish I could get Ghostaccord to chime in on this. I found below a link, is the F22A and B dizzy different and maybe that's the cause of my problem?
https://honda-tech.com/forums/honda-...lease-2937506/
More info about Dizzy on F22b
https://honda-tech.com/forums/honda-...usion-2862951/
