Old 05-26-2011, 07:05 PM   #1
Bravo-man
Bravo-man is cool... so far.
eating oil!!
Well i have been trying to find the reason why my CB is eating a quart of oil every five hundred miles. My compression seems fine and i can not find any leaks so i was going to try to put new valve seals. What do you think about superteck valve seals or should i just go OEM? Oh i what other thing can cause my motor to go through that much oil? Thanks
Bravo-man is offline   Reply With Quote
Old 05-26-2011, 08:54 PM   #2
batever
batever is cool... so far.
if you have ruled out an external engine leak, it can be burning in the cylinders. This would be caused by worn piston rings or, I think, poor or burnt valve seals .
batever is offline   Reply With Quote
Old 05-26-2011, 09:00 PM   #3
deevergote
Don't call me dude.
It could also be due to leaky spark plug tube seals. Check to see if your plugs are covered in oil. ALWAYS investigate simple solutions before jumping to more complicated and expensive conclusions!
Old 05-26-2011, 09:08 PM   #4
esskater892
esskater892 is cool... so far.
have you messed with the oil filter at all recently? i actually found mine to not be so tight and its reduced the comsumption a good bit. also i have replaced my tube seals but it didnt work so i think i have something else wrong. possible warped valve cover or something.
Accord SE
93se
Members Ride
Bought from: H22wagon93, Theos92VR4, Hondafan81, Father Time, DarkHusk, Gunrunner, FamousFreak
Sold to: sulimed, BurtonRiderT6, tishock
esskater892 is offline   Reply With Quote
Old 05-27-2011, 02:28 PM   #5
Bravo-man
Yea deever that is all new with my a6 cam swap. Do you think those valve seals will work or go with oem ones? And then if that is not the problem think it will be the rings even thou it is holding compression.
Old 05-27-2011, 02:36 PM   #6
deevergote
Don't call me dude.
I've never done valve seals, so I can't say from experience... However, OEM is always the best choice in most cases.
Old 05-27-2011, 03:15 PM   #7
SOHC-FTW
SOHC-FTW seems to have made some friends!
Whats the actual PSI per cylinder?
02 Crv
SOHC-FTW is offline   Reply With Quote
Old 05-27-2011, 08:13 PM   #8
madmattr6
madmattr6 is cool... so far.
If the valve seals were the issue blue smoke would be coming out the tail pipe...
madmattr6 is offline   Reply With Quote
Old 05-28-2011, 01:48 AM   #9
Bravo-man
I'm getting around 155 per cylinder +- 10 psi, I am not getting any smoke out of tail pipe. So now I don't know what to try just want it not to eat or burn any more oil.
Old 05-28-2011, 11:18 AM   #10
SOHC-FTW
Perform a leak down test?Compression doesn't seem that bad off, but a leak down will tell you far more.Check main seals?I think you'd see an oil leak if its losing that much.
02 Crv
Old 05-28-2011, 02:53 PM   #11
Bravo-man
Ok,will do. Hope it's some thing small cause I'm still saving for my euro-r motor.
