Old 06-03-2011, 04:11 PM   #1
ontheroad92
ontheroad92 is cool... so far.
cel occasionally coming on
as you may know from my previous post i was having map sensor issue (cel code 5). well, i went and took the car to get a vacuum pressure test and nothing was wrong. actually the cel hasnt been on at all in the past 1.5 months.
so i go to start it to hit my friend's place today and on it comes. it seems to come on occasionally which makes trying to pull a code difficult. it does run a little rough, like it did the last time it came on.
should i go ahead and change the map sensor? anything else that may be causing this? haven't reset the ecu and will try that and let you know what's up.
also was told that honda discontinued this part. should i try aftermarket? if so, what brands do you recommend? go used?
ontheroad92 is offline   Reply With Quote
Old 06-03-2011, 04:34 PM   #2
TypeG
Moderator
TypeG is very helpful TypeG is very helpful
you can still get the code eventhough the cel is not on anymore. should be stored in the ecu. i would read that first and go from there. later.
Avoiding dirt at all costs
TypeG is offline   Reply With Quote
Old 06-03-2011, 04:53 PM   #3
ontheroad92
ok i will go down and try that first and let you know. thanks!
Old 06-03-2011, 05:09 PM   #4
ontheroad92
ok so i managed to pull it and it is a code 5. now i know there;'s some tests that need to be done with a wiring harness. i dont have the equipment. can i just replace the map sensor and i'd be ok?
Old 06-03-2011, 06:23 PM   #5
Jonas
Bronze Member
Jonas is cool... so far.
if cel 5 is telling you that your map sensor is bad, then yes, replacing it with a good one should fix the problem. be sure to reset the ecu after you replace it.
Jonas is offline   Reply With Quote
Old 06-05-2011, 12:33 AM   #6
madmattr6
madmattr6 is cool... so far.
That's horrible advice. Especially in these hard times.
What if its a connector issue?
Just try to find someone with a dvom or even better an oscope. And pull a wiring diagram for the sensor.
madmattr6 is offline   Reply With Quote
Old 06-05-2011, 08:12 AM   #7
Jonas
Bronze Member
youre right, telling someone to replace a part that the ecu is reporting as faulty is horrible advice. connectors go bad all the time in these cars (that is actually sarcasm... ive seen many failed map sensors, never a failed connector for the map sensor)
