Been working on the F22A6 and some pics to share!
    Been working on the F22A6 I picked up. Thought I would show off some pics for everyone.
    Enjoy!
    Nice. more pics please
      Ask and yee shall receive! haha.
      Exhaust side
        What bit did you use to knock those exhaust valve guides down?
          The reshaping was done mostly with Wurth Sanding cone rolls and a mandrel. 60 grit.
          These things.
          Then I switched over to flapper wheels. 40 grit then 60 grit.
            Hmm, I was figuring a carbide lol But I guess 60 grit will get it done
              Yeah, it takes more time but the end result is better.
              You know, thinking back to it, you are right. I went in there first with a carbide and knocked them down most of the way.
                Nice. Makes sense lol Did you open the bowls up any or just "smooth" them out?
                I havent got to check out a F head yet, ported a H22 last year that came out real nice. Gonna do another soon. Kinda nice having those big wide ports, easier to move the die grinder around in there.
                  Very true about the added space! Hah, I didn't even consider that.
                  The valve bowls I didnt really make much changes to. I just smoothed the transitions between the seats and bowl, and removed the castings.
                  The divider on the intake side has been reduced in diameter quite a bit. The roof raised around the valve guide quite a lot as well.
                  The exhaust side, I opened up the ports quite a bit. We will see if it was a bad idea or not. The exhaust side just seems so small on these heads, but then again Honda knows best and perhaps there was a reason for that. After all, people have made great power on stock F22Ax heads with cams and compression.
                  Hoping for 200whp and/or an 11.9 ET
                    Might as well post this, too.
                    Direct bolt on. Crazy
                      Nice homemade balance shaft delete kit. I payed for the KS tuned kit though cause I could never trust myself enough to think I knew how to make one myself and put it all together. haha.
                      “Speed has never killed anyone. Suddenly becoming stationary, that's what gets you.”
                      ― Jeremy Clarkson
                        Dude the KS kit is a good price for a good kit. If I had just a smidgen more spare money I would have bought it. I even sent them an email to see if they would offer a discount for exposure but I think they know they have the market cornered. hehe.
                          I believe the exhaust ports are notoriously small, and require the most work on a F head... I could be wrong tho.
                          Is that a RBC Or PRC mani? Im not up on the K stuff yet lol Im old school I guess
                            Dropped the head off at the machine shop for a clean up, but did a quick mock up first!
                              what intake manifold is that?
