My buddy has an 89 integra and I love the feeling of the steering. I want to swap mine out on my cb7 but I'm not sure if it would fit or not. how could I find that out?
89 integra steering rack swap?
You would need to examine the mounting points of the steering rack to the front crossmember. If they're the same style and the same width apart, then it will likely bolt to your car. You will then have the issue of insuring that your CB steering joint from the column fits with the input shaft on the rack pinion. Once all of that is sorted, you'd need to come up with a new way to get your high pressure fluid lines routed to allow everything to reattach.
It's really not that simple. Most likely, it doesn't even mount up in the first place. There are many ways to change the steering on your car, depending on what you're going for.
Reduce weight
Change the width of the front tires
Run an underdrive pulley on the factory pump
Convert the CB rack to manual steering
Verify that all of your steering components are actually in good working order before changing thingsMy Members' Ride Thread - It's a marathon build, not a sprint. But keep me honest on the update frequency!
To properly delete power steering, you'll need to remove the rack and modify it. Instructions can be found in our DIY section. Otherwise, damage could result. Removing power steering will definitely increase road feel, though be prepared for any bumps in the road to jerk the wheel out of your hands. It took some getting used to for me. Overall, though, if you don't mind the extra effort, it does make you feel more connected to what the car is doing.
Other things to do in addition to what Jarrett mentioned would be to replace all of your suspension components with new and/or upgraded components. It doesn't affect steering feel directly, but by tightening up your soggy old suspension, your car will be more responsive to steering inputs. Look into polyurethane bushings, new ball joints, and new shocks. If you're not lowered and do not want to be, there are affordable stock replacement shocks that will increase suspension performance from Koni, KYB, Bilstein, and Tokico... if you're lowered, Koni has the best option in the Sport (yellow) shocks. If you get into this stuff, just remember to buy quality components, and only get shocks that match the ride height and spring rate of the springs you plan on using.
