Spark Plug Popped out at high RPM
    Good Afternoon,
    I was on my way home from work, and my RA has bad synchos in 3rd gear. Going down the highway I was just playing with Rev matching so I can pro-long the life of my 3rd gear synchros. I was doing 75mph and when I shifted from 4th to 3rd back to 4th back to 3rd just watching the distance between revs, next thing I know I loose power. 75mph 3rd gear was about 5k RPM.
    When I got home I popped the hood and saw that the spark plug wire popped out for cylinder 1 I believe (very right). Had a little bit of oil on the plug and little oil that shot out from the spark plug hole. Put the plug back in, reved it up a few times, everything was fine.
    My question is, what would of caused the spark plug to pop out, they are new NGK plugs and wires and gaskets around the plugs and they are all on snug tight. Could pressure from in the head some how leaked past the gasket and popped it out, has anyone had this problem, and should I worry about it?
    For Sale Thread CLICK HERE!
    1991 CB9 EX Wagon
    1990 CB7 EX Sedan
    1997 RA1 LX Wagon
    CB7Tuner Discord CLICK ME! -- http://www.cb7tuner.com/vbb/showthre...02#post3285402
    I’ve popped a couple in my day. Usually means either you didn’t put the plug wire on all the way or the wire crimp that slides on top of the plug may have gotten loose or enlarged. You can pull the wire a little bit out of the plug where it connects to the spark plug and just pinch it a little with some needle nose pliers. I wouldn’t be to worried.
    ~Nick~
      Okay, if it happens again I'll just pinch it like you said so it stays on more snug. Thanks Grumpy!
      1991 CB9 EX Wagon
      1990 CB7 EX Sedan
      1997 RA1 LX Wagon
        Just to be sure, we're talking just about the plug wire, not the spark plug itself, correct (at one point you say "put the plug back in")?
        How old are the lower plug seals and plug tube seals (at valve cover interface)? If you have oil in the plug holes, then these seals are leaking some allowing crankcase pressure to leak into the plug holes. On my oem wires, there is a small hole (vent?) in the plug wire cap, make sure that isn't plugged with something as well. If you have aftermarket wires, there may not be a vent.
