My First CB7 (all my friends think it's a steal)
    Hey guys,
    So this is my first post on CB7tuner. I've merely skimmed through the forum regarding various topics but i digress. This past weekend, I bought a 1992 Accord EX Coupe (manual). I had been looking for a car for at least three months or so, but I just couldn't find much. When I saw the ad for this CB7, it wasn't my irst choice (it really should've been). Let me start by listing all the parts currently on the car:
    - Some brand of coilovers in the front and shocks in the back (haven't gotten a chance to check but I will this weekend. Hopefully)
    - AEM Short Ram Intake
    - Stage 2 Clutch
    - D.C. Street Legal headers
    - Magna Flow Cat-back exhaust
    - Quick release steering wheel
    - Pioneer head unit (thank God for an aux cable)
    Now this car has two problems, not sure which would be the minor and which would be the major, you decide. The first problem is that the car currently leaks brake fluid from the right front of the car. Again, I haven't been able to get under the car to check but i can see brake fluid from there if I let the car sit for awhile. The second problem is when driving the car hard and fast, second and third gear slightly grind. My thought on that are the car probably needs the transmission fluid replaced but I'm not sure.
    Other than that stuff, the car is great. It's got about 179,000 miles on it and I plan to keep it for a long time (hopefully)
    For now, the only hing I can think about changing with the car is those 15" steelies. I just don't like there look. At all. Deep dish would bee cool, but no. I'm considering trying to go for a "kanjo" style look since I plan to go track the car after fixing the brake fluid leak, but time will tell.
    Here are some pics:
    I have saved the best part for last hehe.
    This car cost me $700.
    Yes, $700
    Welcome to the forums
    Hopefully that brake fluid leak and grind are simple fixes. It may be that your shift cables are out of spec or the fluid as you said. This forum is THE best source of knowledge about CB7's so make sure to use the search function extensively. I can't imagine many issues that haven't been already addressed here. Glad to have ya here Peach and yes, you got a steal of a deal for that car.
      The car looks good.
      I do have a concern and you should as well. Why in the nine blazing hell's are you driving the car "fast and hard" with a leaking brake line/connection/caliper?!? It would seem to me you are asking to wreck, I mean just begging for it almost.
      First and foremost you should probably fix the leaking brake problem before really driving the car all that much if at all. I mean at low speeds you can somewhat negate the issue, with the parking brake if the brakes failed suddenly. Anything above 25 MPH I would consider unsafe with leaking brake lines. Even then that isn't all that safe because if you have to stop immediately the parking brake isn't going to do that for you.
      The grinding of 2nd and 3rd is most likely just worn synchro's. A fluid change might help a bit but the only real fix is to swap transmissions with a known good one or rebuild the one you currently have in the car.
        Originally posted by Rilas View Post
        The car looks good.
        Haha yeah you're completely right in regards to how I shouldn't be driving fast and hard with leaking brake fluid. My only solution to the problem which has been working so far is topping off the master cylinder before I start drving. I'm only using the car to drive to and from home on weekends, but all things considered, leaking brakes are a major issue
          Also I forgot to mention, welcome to the forums! Glad to have another person that shares an interest in these cars.
            Yeah, it's nice to be part of a community that enjoys these Accords. I'm looking forward to years with this car
              So I just wanted to get your guys' opinion on this (but I'm not sure if this would be the thread to place it in).
              After fixing this brake leak (hopefully this weekend), I plan on getting these ADR GT rims once I get my paycheck. The guys has them listed for $150 and I really like they're look. But I want to know if it's really worth it
              The size of the full tires are 205/45 R 16
              Here are some pics:
                well if our (or at least my) opinion matters I'd suggest holding off on modifying the car until you have all of the maintenance issues taken care of and the car is reliable and safe to drive. THEN it would be acceptable (in my opinion) to start modding your car. Do as you choose, I'd just hate for you to have a broken down car or one that gets into an accident with snazzy new wheels on it.
                  Oh yeah, I completely agree. I want to fix this thing to where all I have to worry about is how much gas i have left rather than how much brake fluid is left. Reliability is my first goal. It sucks that I have to drive this from LA to Riverside (80 mile drive) this Friday night because I'm gonna be worried the entire time. I want to fix this brake fluid leak ASAP but I have no where to work on it out here in LA. I was just wondering if ADR GT wheels are a good fit
                    So here's an update on the vehicle:
                    I've changed the valve cover gasket because I was experiencing misfires and found motor oil in two of my spark plugs. Also, I found some guy selling a full set of rims for $50 but one rim a small weld. Paid $150 for a better set of used tires. Then I went on to retrofit the AC and now the car runs good. Yeah, she's still leaking brake fluid so I have to find someone to hep with either an ABS delete because that's where it's leaking from. The ABS reservoir overflows and leaks the brake fluid. Saddest part is it's eating through the paint on my AEM intake
                    Here are some pics:
                    In regards to future plans, I really love the idea of a v6 swap when this motor takes a crapper or if I can find a good one at a pick-a-part. If not, individual throttle bodies have always been my love. I just wish I knew where to go from the standard I/H/E mods for the ITBs
                    P.S. For those with better eyes, you may have noticed a big scratch in the right back tire area. Yes, I am sad to say that I scraped while trying to get out of a parking garage AND while trying to parallel park. It dented the fender and has left a lot a deep scratches. I've been looking into how to repair it but time will tell if I can
                      Don't worry bro. We will fix the brakes and abs this weekend. We gotta hit Rialto pap early so I can get the plugs to wire up the Acura CL seats in your car. At least the power for now. As long as you got a lil time I'll fix that car right up.
                      ~Mark~
                        Hell yeah man, I'm excited for it all. Can't wait for the weekend
                          The pictures don't seem to be working, I'd love to see the car!
                          I'm faster then a prius
                            Glad it's not just me, pics don't show up on my end.
                              That's so bizarre. Looks like google photos doesn't support third party hosting. I'll try and find a way to have them up someway or another
