I would like your opinion on what to invest into my car. I am about to replace my F22a with a F22B DOHC and I would like to hear some input on where to put money and try to make my car better. Oh, btw, I would love for my car to remain a sleeper and not overly extravagant on the exterior.
Where to spend money first?
What is your end goal? What is your experience level? What is your budget?1993 SE Coupe MRT - 1992 LX Sedan MRT
Maintenance. Preventive Maintenance. The stuff that has been neglected for years. And clean it. Then worry about engine swaps or whatever.
If a person cannot or doesn't want to do the maintenance then they will surely not know how to or will not have good results with engine swaps and such.Last edited by H311RA151N; 10-02-2014, 09:35 AM.
Originally posted by wildBill83 View PostWhat is your end goal? What is your experience level? What is your budget?
Preventive maintenece. While you have the motor out, its a great chance to change things like water pump, head gasket, ect. A lot easier to get to everything with the motor out of the car. Change any bushings you need to change, wheel bearings, things that tend to break ya know.93 4dr ex 5 speed
97 Integra DB7
Originally posted by H311RA151N View PostMaintenance. Preventive Maintenance. The stuff that has been neglected for years. And clean it. Then worry about engine swaps or whatever.
And fix your damn transmission issue before you go doing engine swaps and the like! Throwing go-fast parts at your car won't do any good until you fix the other things that make it function properly. Repair and replace anything that isn't working properly. Refresh your ENTIRE suspension. Adding power to a car with a worn out suspension will only make the car dangerous.
These are old cars. They take a certain degree of attention before modifying them. If you're not up to that, sell it to someone who is, and buy yourself a newer car.
