Two questions.... does neone kno where i can find the wiring diagram for the CYP sensor for the f22b1 for a 97 accord?? and i am running an obd2 f22b1 on an poa from a 94 accord i know that the 97's dont use a vtec pressure switch and my car is throwing a code for it will the vtec still work with out that pin hoked up?
2 questions
Helms Inc, cause the online freebees are 1994-95 spec. Some of the wiring is in the same pin locations, but then most of the colors are different. As far as the pressure switch, it sounds as if you already know the answer to the question: you have a sensor missing from your array, the ECU is looking for it, the ECU recognized a problem and stored a code; I don't see why the ECU would engage the VTEC without being able to monitor the pressure. Perhaps I'm wrong.1997 Honda Accord EX-V6:
C27A4 - 2.7-liter 90º-V6 with SOHC, 24-valves, PGM-Fi
MPZA - Electronically controlled 4-speed automatic, 1 reverse
~170 cu. in. / ~170 ft. lbs. / ~170 whp
Originally posted by James MatteuYou have to consider the results of your test in an objective manner, or as the country folk like to say, "son, you gotta be smarter than what you're workin' with."
