Overheating and fan won't stop running!
    Hey!
    Just the other day, my car idles up and down from about 800 to 2000. After I drive anywhere, my fan kicks on just as I turn my car off and get out. Then just today, it started overheating when I drove 10 miles to walmart.
    Please help me! I have no idea.
    There's plenty of info here, just search
    Idle issue? IACV, FITV, or Vac issue.
    It's normal for the fan to kick on after driving. Check resistance of the switch anyway.
    Overheating problem could be a number of things. Are you going through coolant?
    life is good.
      Thank you! I'm going to have to check the coolant tomorrow! It's waaaay to cold to go out tonight. It probably is leaking though. Last time I checked, it was bubbling out of the fill tank a tiny bit. I plan on replacing the whole thing soon.
        Have you checked the coolant level?
        My 5.7 LS1 Holden Ute
          Not yet. What radiator do you have? It looks sick!
            Check that first before anything else.
            I have a Half size Aluminium Radiator on mine.
              What brand makes it??
              Thanks d00dz.
                Check/Replace Radiator cap, test for proper thermostat operation, but I'm 99% sure that if you saw coolant bubbling out the fill tank, your headgasket is toast. Especially if you notice any disapearing coolant, but no signs of visible leaks.
                What ends up happening, is exhaust gasses escape into the cooling system, and it creates a high pressure bubble in your cooling system. Once the pressure of the radiator cap is met, it starts pushing coolant and/or exhaust gasses into your resevoir, which eventually gets full, and overflows (Oh the irony in the name of the overflow bottle)
                FYI you add coolant by removing the radiator cap, and loosening the nipple on the thermostat housing to bleed air bubbles out of the system as you fill the radiator, when the coolant coming out of the nipple no longer contains bubbles, tighten it up, while topping off the radiator.
                Oh and air bubbles in your cooling system has been known to cause idle issues for other members (even though its never happened to me)
                  as for your idleing problem..its air bubbles that get stuck in your iac sensor..and you probly def got a head gasket problem. check the front of the block to see if the is a green residue on it..if so then def got a bad head gasket. and the "rad" u r talkin about is a intercooler (its for a turbo setup)
                    demon has a giant front mount all up in there...
                    life is good.
                      For head gasket problems -Check to see if exessive steam is coming from your tail pipe too. This is a sign of water getting in the combustion chambers.
                      It may be difficult to tell in cold weather though. Another method is to check for milky or milking engine oil via the dip stick or oil filler cap.
                      However another possibility for the overheat is a faulty thermostat that doesnt open up completly or stuck shut. Remove and replace or just plain remove it for now and see if it still overheats.
                      Rides:
                      Accord
                      CR-X
                      88-JDM-Si- Black
                      CR-X Del Sol
                      92-JDM-SiR "Transtop" - Black
                      Prelude
                        I disagree as I once made a mistake of not reconnecting the electric fans after removing a radiator and the car overheated. The car had boiling water trying to come out of the reservoir (since it has a screw top lid) but it didnt mean the cars head was blown.
                        Water trying to make its way to the reservoir in my opinion is due to the overheating (not necessary a head gasket problem). A head gasket problem can lead to overheating but overheating is not necessarily a head gasket problem.
                        Rides:
                        Accord
                        CR-X
                        88-JDM-Si- Black
                        CR-X Del Sol
                        Prelude
                          Goodluck and let us know how you go.
                          Cooling is a major problem and would like to know your fix so i can keep it mind when my one plays up.
                          Rides:
                          Accord
                          CR-X
                          88-JDM-Si- Black
                          CR-X Del Sol
                          Prelude
                            True dat. I think I'll just replace the head gasket and try that. I've done as much as I can to try to fix it today. I do think I noticed some of the green residue though. Where's a good place to buy a new head gasket? Advanced auto parts? Let me know so I can stop by after work tomorrow.
                            Thanks a lot for everything. It's GREATLY appreciated!
                              let me know what the Idle Problem turned out to be im curious
