RPM launch?
This topic is closed.
    RPM launch?
    i have a 1990 Cb7 stock just with bolt-on's
    what is the best RPM to launch it at?
    anyone? ive launched it 5,500rpm and it does wheel spin alot so i know its not that... i dont want to waste my tires trying to find out so someone can you please help me?
    what do you know about tire pressure.
    I <3 G60.
      well i have regular tires with regular tire pressure.
        you have a 5 speed right?
        view my ride: My Ride
          Whats your tire pressure and size?
            its auto lol
            14" and with regular tire pressure. idk what it is i havent checked but its what the guys at the tire shop put on them.
              Quit doing neutral launches in your auto.
                why? i been doing it for about a year. no problems.
                  one day it will be a partsscatter. later.
                  Avoiding dirt at all costs
                    my car has 290k miles and ive always high revved it for about 2 years and been launching it at 5,000 rpms for a year and nothin has gone bad with it. ive topped it out at a lil over 130mph aswell several times. and my car still runs smooth when im driving normal.
                      Well then go ahead and keep doing it then it's your car.
                      when it goes out more reason to do a manual swap.
                        ...Yet.
                        When your in neutral revving it up like that and you shift into drive, the clutches inside the automatic transmission end up initially slipping for a while (excessively), which is not good on them. Normally if your RPM's are low most of the "slippage" happens inside the torque converter where its supposed to.
                        If your really looking to launch faster with an automatic, you could hold the brakes and give it a little gas (in drive, at a stop) to kind of "pre-load" the torque converter. Of course thats not good on things either- your generating alot of heat and can very well break many components, but I suppose if you must, then its probably a little better on it than a "neutral-drop"
                        Besides if you have an automatic transmission designed almost 20 years ago for reliability and fuel economy, its not supposed to be "fast". Trying to force it to go faster than intended will most likely cause failure of the transmission.
                        Dont get me wrong, everyone wants to go fast, but you need the right equipment. Get a 5-speed swap (or a factory 5-speed accord), and get whichever clutch you want, and you can launch at whatever RPM you find is best!
                        ON_N20
                        Nitrous = Been there. Turbo = Now. Nitrous + Turbo?... LOADING
                          its auto lol
                          ok heres my vid on an auto launch..
                          tire size is 205/55r15s pressure 35 on all four
                          basic bolt ons
                            to prevent wheel spin, you need to lower your tire pressure and launching rpm.
                            I <3 G60.
                              Dude what do you race with a heavy ass automatic accord? Cause two stock accords racing ain't a good scene if you ask me.
                              92 Accord Cb7 ^^
                              My Ride Thread~~Click Below.
                              http://www.cb7tuner.com/vbb/showthread.php?t=176232
