f22a1 an interference engine?
    Sorry if I sound like a complete noob but is the f22 an interference engine? My timing belt snapped a couple of days ago and just wanted to find out so I know exactly what to do. I hear it isn't then it is so what is it?
    she is down....but definately not out
    It is definitely an interference engine. As is the H22. I know that from experience.
      If you broke the timing belt you can go ahead and take the cylinder head off. You almost definitely bet valves.
        This is the first time this has happened to me. I was told that I would have heard some sort of internal contact between the valves and pistons.
          Unless it was at idle when it broke then you probably bent some valves. It may have bent them even at idle. As Jarrett said, you might as well pull the head and check everything out.
          That is exactly why pork chops don't taste like chocolate!
            When I took my timing cover off I saw the timing belt was on the outside of the gear, on the right side instead in the middle.
            Is it possible for a timing belt to slip off the cam gear?
            Do a leak down test or a compression test.
            “Speed has never killed anyone. Suddenly becoming stationary, that's what gets you.”
            ― Jeremy Clarkson
              No. was traveling at around 35 mph barely any load on the motor. It sputtered and the car was jerking till I brought it to a stop. I noticed the rpms dropped to zero. I had this happen to another cb and it turned out to be the main relay so like a dummy I assumed the same. I checked today by taking the dizzy cap off and when cranked over the rotor didn't turn. I figured as much as fast as the starter was spinning the motor. Any ideas on the cheap?
                Do a leak down test or a compression test. You will tell if you have good valves or not.
                ― Jeremy Clarkson
                  You cannot perform those tests on engine with a broken timing belt. I mean, you can try it. But the result is meaningless.
                  A&P-IA
                    I think I am just going to start tearing it down. Will give me a chance to check things out, replace seals and other things.
                      Actually you can. Here's how. Remove the valve cover loosen all the rocker arm or valve adjusters this will allow all the valve to close. Do a leak down test on all the cylinders. If there is a leak then you are a few steps closer to removing the head. If there are no leaks then the cam can be turned without fear of bending valve. Line up all your timing marks and replace the belt don't forget to readjust the valves. It is worth a try.
                      IT IS WHAT IT IS
                        If the timing belt is broken, the cam shaft is not going to turn as you turn the crank. Please tell me how you could test compression properly on ALL of cylinders on such engine.
                        Why do you want to got through the trouble of replacing the broken belt when you know the engine is an interference engine?
                        It will be a waste of time if you ask me.
                        A&P-IA
                          If you remove the rocker assembly, all of the valves will seat, both intake and exhaust, on all cylinders, at the same time. No need to turn the cam shaft, as all valves are already (and always) seated. That is of course assuming they aren't bent; if they're bent they obviously won't seat properly and you will know this because that cylinder will leak. Significantly.
                            Yeah, I didn't think of that trick. I hope it would work for the op.
                            With my experiences with interference engines, I was not lucky at all.
                            A&P-IA
                              It's actually a fairly straightforward procedure, quick, easy, and decisive all in one! That's a rare find, . Either way, unless you were in neutral at 35, you're going to be tearing down that head, and most probably the whole block.
