Grumpys93: 350whp build; The last episode
    So i decided to go ahead and post this.Ok so keep in mind this is not going to be a build that will happen over night my set time is 1-2years or more lol. I have been doing my research for about 3-4 months and have pick my parts carefully and this set-up probably change.
    My 350whp+ build
    Engine:
    -F22B DOHC Non Vtec Head<<< Bought >>>
    - Bisimoto 2.4 turbo cams
    - Bisimoto non slip cam gears<<< Bought >>>
    - Bisimoto F22B springs and retainers
    - Pnp valve job
    - OEM Head gasket kit
    - Timing Belt(gates or OEM)
    - Head resurfaced<<< Done >>>
    - Replace valve guides<<< Done >>>
    - Supertech H23 Valve stem seals<<< Bought >>>
    - Bisimoto F22B Stainless Steel Valves<<<Bought>>>
    -F22a4 Bottom end<<<Done>>>
    - APR headstuds<<< Installed >>>
    - ACL Main Bearings<<< Installed >>>
    - Wiesco 85.5mm 8.8:1 low comp pistons<<< Installed >>>
    - Bisimoto Steel h-beam Rods<<< Installed >>>
    - Crankshaft micropolish and magnafluxed<<< Done >>>
    - APR rod pins<<< Installed >>>
    - OEM Oil Pump<<< Installed >>>
    - OEM Water Pump<<< Installed >>>
    - Honed (Work Done by DFE)<<< Done >>>
    - Bored to 85.5mm (Work Done by DFE)<<< Done >>>
    - OEM Oil filter<<< Installed >>>
    - BOMZ Underdrive Crank Pulley<<< Installed >>>
    - H23 lower timing gear<<< Installed >>>
    - H23 lower timing gear guide<<< Installed >>>
    - OEM Block Gasket kit<<< Installed >>>
    - KaizenSpeed Balance Shaft Eliminator kit<<< Installed >>>
    - ESP Solid Motor Mounts <<< Bought >>>
    -Intake System
    - KMS EGR Block off plate(To replace my ghetto block off)<<< Installed >>>
    - PNP Gutted f22b intake manifold<<< Have >>>
    - Omni Power 70MM Throttle Body<<< Bought >>>
    - Bisimoto Intake Gasket<<< Have >>>
    - Coolingmist Meth/Water injection system
    -Fuel System
    - AEM Fuel Rail
    - Walboro 255 Fuel Pump<<< Installed >>>
    - Precision 1000cc injectors
    - AEM Fuel Regulator
    - Summitracing Fuel Pressure Gauge
    -Forced Induction
    - Custom Tubular Exhaust manifold<<< Have >>>
    - Precision Sc6262
    - Tial 38mm Wastegate<<< Have >>>
    - Tial 50mm BOV<<< Have >>>
    - Mishimoto G-line FMIC<<< Installed >>>
    - 2.5 intercooler piping
    -Exhaust System
    - Custom 3" downpipe
    - Glasspack Resignator<<< Installed >>>
    - Megan Racing Muffler<<< Installed >>>
    - Mandrel Bend 3" piping<<< Installed >>>
    - Y cut-off valve
    - SummitRacing electrical exhaust cutout
    -Tuning
    - Neptune RTP Demon Package
    - Chipped p06<<< Installed >>>
    - GM 3 bar Map sensor
    -Transmission
    - New ACT HA3-XTG6 Clutch
    - Fidanza aluminum flywheel
    - Tranny Rebuild
    - Mfactory LSD
    -Misc
    - NRG Quick Release Hub 2.0(Red)<<< Bought >>>
    - Defi Boost & Oil pressure gauges
    - VIS Carbon Fiber Hood OEM style<<< Bought >>>
    - Carbor Fiber g-square style grill <<< Bought >>>
    The Car
    I will be updating this thread as parts come in and if i update the list. Please feel free to comment with your ideas thought and criticism
    goodies omnipower tb, Bisimoto intake mani gasket
    and wiesco pistons
    ~Nick~
    Got the block back from the shop its is nice and pretty Work done: Bored to 85.5mm, Honed, Decked, Hot tanked, Powdercoated
    Head before taken to the shop:
    After having them check it, hot tank, replace valve seats and valve stem seals and have the head resurfaced:
    Thinking about trying to port and polish myself but it will only be the exhaust side we shall see.
    I plan to go get the pistons and rods pressed in this week:salook: Also dropping the crankshaft off to get micropolished
    ~Nick~
      Started doing a little wire tucking on the driver side
      Before:
      After:
      I am going to fill in the holes next weekend as well and i need to find someone who can weld up those two big holes from me. But ya lmk what you think.
      ~Nick~
        Exterior
        ~Nick~
          *reserved
          ~Nick~
            Awesome build man, can't wait until it's finished!
            *Click on photo for my MR thread
              Originally posted by HybridKyle View Post
              This guy is ghey and the motor is ghey
              Reserve that beeeotch!
              Lol are you butt hurt because i couldnt stop by? She was complaining and she wanted to sleep because she had a bad hangover
              ~Nick~
                Just curious where you stick all of the stuff when you take it out of the engine bay?
                did you have to extend wires?
                  subscribed
                    Looks good bro, just don't call me when you start the passenger side lol jp
                      i only had to extend one plug that went to the fuel system it was 3 wires. But i cut a hole just behind the strut tower and routed the wires through the fender and in front of the headlights it was fairly easy just make sure to disconnect your battery or else u will fry ur multiplex aka fusebox
                      ~Nick~
                        Ok sweet. Yeah Im going boosted as well, and I was just wondering about that.
                        i figured Im gonna have the car apart anyways haha.
                          Finally pulled the old motor so i can start prepping the bay for paint and shaving/wire tuck
                          I think this guy is going to steal my car when its done he stood and watched the whole 2 hours it took me to pull it including when i left for the store to get parts when i came back he was still standing there lmao
                          Like my new lift?
                          Im watching u!
                          ~Nick~
                            cool man. lookin real good!
                            oh yeah, not you the car! sheesh!
                            MadLab Racing
                            Southern Maryland
                              looking good Nick
                              Accord Of The Month January 09
                              Accord Of The Year 09
                              My 2 Babys
                              BMW TECH FOR 15 YEARS
