Go Back   CB7Tuner Forums > Site Features > DIYs > Engine DIYs
Old 05-23-2010, 12:08 PM   #41
CyborgGT
Question
Here's mine, with the new pump in. It was a bit tight, but as I neglected to tighten down the lines before testing, a bit of fuel sprayed errrrvrywhere and now I don't mind waiting a while to make it a bit bigger/easier for the next time. Cover plate coming soon...ish.
Old 06-22-2010, 10:48 PM   #42
xaaronx
xaaronx is cool... so far.
Send a message via AIM to xaaronx
cut mine open today. just used tin snips and cut a rectangle. i tried to keep it as one piece as possible so that i could attach a hinge and mending plate to keep it down. looks like kind of a hack job right now because it got dark and i was trying to rush. tomorrow i'm going to grab some sort of rubber trim and put it all around the edge to keep it sealed.
i'll grab pics tomorrow once it's done.
90 ACCORD EX..<-- MR thread
xaaronx is offline   Reply With Quote
Old 06-23-2010, 12:59 AM   #43
Tippey764
Silver Member
Dropping the gas tank isnt that hard guys... lol
Its just 4 bolts and a few fuel lines to disconnect.
Tippey764 is offline   Reply With Quote
Old 06-23-2010, 04:06 PM   #44
xaaronx
i don't imagine it being hard but my car is currently parked in a rather busy street and can't get it started to move it lol
update on my fuel pump situation:
went to start my car this morning and NOTHING. went ahead and ordered a 190lph walbro. so, i started ripping everything apart again to get my old pump out. two of the nuts on the lid thinger ended up getting stripped because they were so corroded had to buy a nut extractor and spend far too long on just those two nuts. now to play the waiting game for this new pump to arrive....
Old 08-13-2010, 03:45 PM   #45
batever
batever is cool... so far.
Interesting DIY. I always do like to say that "it isn't yours 'till you've drilled some holes in it."
I would be concerned that if there were any fuel vapors above in that area with the cutoff wheel--bye bye.
Also (just a question)--never dropped a tank before, but can't you just use a floor jack to lower it and press it back up?
Also, if you ever have severely rusted bolts, try CRC Freeze-off. Normally PB Blast is my tool of choice, sometimes spraying it on fasteners 2x a day for several days before a job, there but for a really really bad bolt I use my can of CRC Freeze-Off. It's messier (drips all over the place because you have to spray it on the fastener for like 15 seconds at a time) but gets those really hard jobs done faster than the PB Blast.
batever is offline   Reply With Quote
Old 02-26-2011, 03:00 AM   #46
SN2BH22CB7
SN2BH22CB7 is cool... so far.
Send a message via AIM to SN2BH22CB7 Send a message via MSN to SN2BH22CB7 Send a message via Yahoo to SN2BH22CB7
I'd make the hole just a little bigger....because the pump comes out at an angle ..so more clearance is best. Make the hole bigger on the side of the angle.
Nice DIY!
92 LX. A6 with GUDE bullfrog Cam. M2S4 transmission..Gutted H23 intake mani. The rest you will just have to find out!
MR Thread:
http://www.cb7tuner.com/vbb/showthread.php?t=174586
My tribute page: http://www.cb7tuner.com/vbb/showthread.php?t=70489
SN2BH22CB7 is offline   Reply With Quote
Old 02-26-2011, 06:01 PM   #47
HATCHing
HATCHing is cool... so far.
Nice.. I thought about making it on my CB too but never really need to make one yet.
Checkout my MR: http://www.cb7tuner.com/vbb/showthread.php?t=165984
HATCHing is offline   Reply With Quote
Old 02-26-2011, 08:38 PM   #48
Noridetoolow
Noridetoolow is cool... so far.
Good idea, I would do as a couple have suggested and use a cover plate from a Civic or any other car that has an access panel to the fuel pump. Granted it has to fit the limited space on the CB but im sure something is out there that is available. You can also use the hole in the donor vehicle as a template and if your really pimp, cut out the access hole and weld it in place on your CB.....would DEFINATLY drop the tank for this....and this is of course taking this mod to the extreme but would be the cleanest option out there! EIther way, nice thing about using an OEM access panel is that it will look and function like OEM and would actually give some of that space back some of its structural integrity though I doubt cutting this small hole would ever be noticed unless the car was being raced or something similar.
Bought from Darkcloud
http://wheelflip.com/r/DrAkE
Noridetoolow is offline   Reply With Quote
Old 11-24-2013, 07:13 PM   #49
Bullhorn7
Bullhorn7 is cool... so far.
Just did this. Il post pictures later. If you look at above pictures youl notice a steel line of some kind on the seat side of the hole. Theres a bolt holding some other line together under it. The first steel line makes it very difficult to do this mod and get to the lower bolt. so I just cut the above bracket away and made it easier.
-Will
Bullhorn7 is offline   Reply With Quote
Old 11-24-2013, 10:19 PM   #50
Black_Soul
Black_Soul is cool... so far.
Send a message via Yahoo to Black_Soul
just seen this great idea. guess ill replace my ex girls fuel pump the same way lol. so if i f up i know where to go on mine
underground Society 757
Black_Soul is offline   Reply With Quote
Old 07-05-2016, 09:38 PM   #51
CB9
CB9 is cool... so far.
Does anyone have pictures of this done on a CB9 wagon? It would be helpful to see where the pump access opening should go, as obviously the contours of the wagon's floor is somewhat different than the sedan.
CB9 is offline   Reply With Quote
Old 07-06-2016, 08:29 PM   #52
CB9
Never mind; I guess it's not really that much different than the sedan:
http://www.cb7tuner.com/vbb/showthre...73#post3258773
diy fuel pump
