91 CB7 Shaking When I Brake
    I have a problem with my steering wheel shaking when I go to stop. Worse at higher speeds. Replaced the rotors, pads, wheel bearings, tie-rods, upper control arms and ball joints and sway bar end links. Do you think these Napa rotors could be the cause of the shaking? Not much else to replace.
    Thanks
    Do a runout test.
    wat?
      Sounds like you need those new rotors turned.Very common to get warped new rotors.
        I've never heard that. I don't think it would be common place to sell a broken part.
        I'd say replace them or turn them.
        MRT
        sneaky motherfucker
          http://www.youtube.com/watch?v=5xIUAMl-oRQ
          BAM DUDE! i used this diy to replace my front brake rotors.. No more shaky braking.
            Have you checked the actual brake caliper? It could be that the piston is not compresing all the way and it could cause the brakes to grip more on one side and could cause it to shake. How about your tires and rims are you rims bent anywhere and are your tires evenly wearing out check the tire tread and see if it's even on both sides.
              My rims are not bent. Checked that also. Plus has new winter tires on the car. I have heard of Napa selling bent rotors.
                That has to be one of the coolest ways to separate the hub from the rotor. Never seen it done like that. I used a hub puller when I did my rotors. Thanks for the link. I learned something new today. Does that mean I can go home now...lol
                  Yeah if you used a puller you maay have distroyed the bearings, that willl give you a vibration.
                  wat?
                    Defective Rotor. Even though it brand new.
                    Bring the rotor back and get a replacement. Try not to get a beat up box
                    This happen on my corolla.
                      yea there probably not parellel
                        This is the BEST youtube video ever! Next time I need rotors my laptop is going to the garage with me.
                        93blackcb7: If they're not parallel, then he needs an alignment
                        MRT
                        sneaky motherfucker
                          If the rotors are refundable then get them replaced... Brembo blanks are what I have on mine and are great... if you get the chance to swap out to a set of them, do it... great value for price...
                            Buy some new rotors and that should fix the problem
                            92 cb7 http://www.cb7tuner.com/vbb/showthread.php?t=176886
                            91 cb9 wagon
                              wheel bering
