the other day I was crusing around. And after a while I noticed my turn signals werent working. Hazards worked though.
Played with it for a while, and if I turned the switch ferom either right to left blinker and pressed the hazard switch just a little, they would work. Kinda hard driving around in a standard and having to hold the hazard swithc at a certain point so they would work.
Finally got a chance to look at it today, noticed my reverse lights werent working either. All fuses in bay and under dash are good. There are 3 relays on the under fuse dash that are at the top of the fueses. Replaced all 3. Im pretty sure the 3 pin one is the turn signal relay.
However since I noticed the reverse lights arent working either im sure its not the relay any how. Also sure its not the switch since the signals work when i push the hazard switch to that point.
Any ideas guys? Any relays i might be missing?
