Just thinking out loud here guys.
h22/f22 hybrid has been done. This frank motor is not known for reliability seeing the f22 block cant spin fast enough to make use of the h22 head.
Why has no one tried to put a worked over f22 head on to the h22 block?
1. Its agreed that the f22 has a better flowing head design and once the exhaust side is opened up and add a larger cam and springs upgrade this head would be able to handle 7000-8000rpm very well. And with a cam such as the bisi stage 2 should pull pretty well from 3500 and up. Correct me if I'm wrong.
2. h22 block is already able to handle the 7000-8000 rpm as is in stock form.
What I'm thinking with higher compression pistons in the h22, and a fantastic flowing f22 head I believe this would make for one hell of a all motor beast.
Realistically speaking this should make about 200hp if not a little more. What do you guys think would be needed to pull this off. Such as what Timing belt? I think the f22 timing belt would work and just having to swap out the the h22 lower timing gear with the f22's gear and should be good to go.. Again I'm just thinking outside the box.. Gimme some feed back guys. Thanks.
