need brake line help
    so the rear brake line blew out and i cant find a replacement part its not the short lines it a really long line the leads into the drum and its rubber coated i pealed 1 inch of the rubber off and there is a metal line in it that has rust i want to post a pic but looking at the rules i don't think i can Adman plz help idk what it is it would be easier yo just put up the pic (RRT)
    https://flic.kr/p/ELMAhy
    Well replace the line. If you go to any napa/auto zone nearby they should have the line in stock or there within a few hours. Just unbolt the ends of the line , install the new line and bleed the brakes.
      Your answers to posting pictures are found in the sticky threads that you should be reading first.
      http://www.cb7tuner.com/vbb/showthread.php?t=55195
        heres the line
          That's the parking brake cable. It's completely mechanical and not hydraulic at all. Unless you just want to replace it for the sake of cleanliness, or if you're beginning a concours restoration, I'd leave it alone. Assuming it works, anyway.
          So, does your parking brake work just fine?
            yeah
            yeah the hand brake works but other then that there is no pressure to the brakes when you push them
              Then attempt to bleed the brakes an/or find the leak. It has nothing to do with that cable, I can assure you.
                Thanks man your a big help saved me time
