HCoupe : 1992 Accord EX
    When I first got my completely stock CB7 (May-2012):
    I did everything by myself, with a little help here and there. If you pretend you have $250 monthly car payment and can make religious trips to the junkyard, you can do all of this in no time!
    ENGINE & TRANSMISSION :
    HMO JDM Euro R(2015), I've put about 70K since then.
    H23 Manual tensioner conversion
    Rosko Racing EGR delete & cover plate
    Rosko Racing 2 wire IACV adapter plate
    Rosko Racing fuel rail adapter plate
    Rosko Racing throttle cable mount
    No balancing belt
    Replica Tri-Y header 2.5 collector
    2.5 inch exhaust to a '15 Civic Si can
    Generic intake tube & cone
    CD7(P0A) power steering pump & bracket
    P13 ECU from HMO back in '04 just happened to be socketed, had Joe @ LoCash Racing chip it, with a dyno tune he had saved. Also Deleted the EGR and knock sensor.
    M2S4 case, M2F4 1-4, .685 fifth, carbon synchros and a Quaife LSD
    Act 8LB flywheel
    Exedy KHC03
    190LP Walbro fuel pump
    LX rear mount + front & rear urethane mount insert
    EXTERIOR :
    JDM headlights stock lights
    OEM Fog stock lights w/ Lexus yellow cone
    LED bulbs front and rear
    Ebay plastic Grille
    32% tint
    Shaved emblem holes and antenna hole
    JY 95' KA8 lip
    JY 4 door trunk
    JY "Si" tail lights
    JY CD5 sunroof visor
    Rear window visor
    INTERIOR :
    JY BB6 SH Cluster
    JY front & rear dash mats
    JY OEM floormats
    JY DC2 clock
    JY CB9 trunk cubbies
    JY 17' 5 spoke spare
    SUSPENSION/WHEELS/RESISTANCE :
    Neuspeed "race" lowering springs 2.25"F, 2"R
    Truhart lowering struts
    Ingalls +1.5 to 3 degree camber correction
    Prothane urethane front & rear master kit (85% installed)
    1' Brake master cylinder
    JY '03 TL knuckles + ABS sensors
    JY '07 TL type S brembo four piston calipers
    Front '07 TL type S EBC BSD rotors
    Rear '02 Accord EBC BSD rotors
    Brembo pads
    Goodridge steel braided lines
    '17 TL type S rims
    215/45R17 Falken Azenis RT615K
    SECURITY/AUDIO/ELECTRONICS :
    Kenwood KVT-514
    4 Kenwood Speakers
    2 way remote start alarm
    LC9
    870
    Also, Everything works from the factory, even the ABS!
    Currently:
    Let this be a PSA don't cheap out on brakes and tires!!!! Your life depends on them. Also having holes in your rotors is dangerous, ask EBC
    I'm open to suggestions, opinions, and insight.
    nice showing brother, Looks like you have indeed been studying this forum.
    CB7TUNER.com
      I love what you did! It's a real sleeper, I miss my old coupe
      So are you keeping it stock height? Word of advise I'm lowered and wish I could be stock height again
      Bought from:AbsurdNY,92smokeaccord,cb7inct,nevi325,xkjnboix,cb 7resurrector,JoshM
      MRT: http://www.cb7tuner.com/vbb/showthread.php?t=203451
        lol right at 30 posts, somebody isn't playing around.
        YouTube Clicky!!
          This is nice. I'm happy u shared her.
          My 90 coupe Mr thread....
            A better camera is needed.
            '94 JDM H22A: 178whp 146wtq
                Damn, nice new pickup! Did something happen to the 'lesser' H?
                Love the coupe, btw, the polished stock wheels are a classy touch. If you're still on the fence about lowering it, the 2" drop provided by most popular springs still gives you useable ground clearance for speed bumps and winter driving. It'll visually close up that fender gap without it looking like your car is lowered compared to other, more modern, cars on the road. As long as you don't drive it like a truck, thinking you can take everything at speed. I never experienced bottoming out, at least...
                Accord Aero-R
                  Thanks. Nothing, it runs strong. I was gonna go all out on the paint and body at a friends shop and drop a grand on materials and have him just spray it. But, a different friend and I have been talking about how we think the JDM engine well is gonna run dry soon, especially the OBD1 H22A. At first I wanted a spare HMO OBD1 H22A as a coffee table, but them blue top H23As are a little easier on the wallet. In the end I went with my brothers mantra with cars " If you are gonna be a bear, be a grizzly" and his engine that he has been hoarding. I went this route because of the rarity and from the factory reliability. That fresh HMO beauty is setting me back. It's going down one of threes ways; replace, reimburse or my current H and a grand, right when my tax return comes in. That a$$hole left it at my house a month ago, It's sitting in my front room, I stare at it everyday. Now I'm gathering the appropriate components for the swap, luckily it'll cost me less than $300 for all the parts. I should have it in my car the week I get my tax return, and dyno tuned no later than summer. Also I got a nice digital camera. After the swap, I'll upload pics of how I prepare the engine and the swap itself.
                    So it begins.
                    It was ready to come out at 7:30, but my friend couldn't show up till 8:30.
                    Time to clean, my power steering system was leaking everywhere. Hot water, Palmolive, and lots of toothbrushes.
                    I brought this pile(minus the rack) of metal to a car wash. I used engine degreaser, toothbrushes, and then the pressure sprayer.
                    Lol
                    Much better.
                    Here she is cleaned up.
                    It's pretty now.
                    Had the Header welded up, to fix the leaks. Grinded off all eye lids and applied multiple coats of high temp black spray paint.
                    Wrapped the header with the remaining wrap from the first time I did it. Only wrapped #2 down, but I did have enough left over to wrap the other runner at the bottom of the header.
                    Switched to the Lx/Dx rear mount, with a rear mount insert from losiracer2.
                    Bought a rebuilt rack, replaced all the rubber P.S. hoses, minus the three closest to the V.S.S.(they'll be replaced soon).
                      Nice job , engine bay and tranny came out squeaky clean.
                        The engine.
                        Thanks!
                        Finally found an OEM coil bracket
                        Manual tension conversion
                        Just one wipe, cleaned that area.
                        Someone went through the front end of this engine right before it went to the wreckers.
                        Did add the retainer.
                        Had to find an USDM H22aX timing mount.
                        I replaced the rear main seal, the oil cooler seal, the two coolant hoses to the oil cooler, and modified the wiring harness. I'm keeping it OBD1 and will be replacing certain parts later on, rather quickly, because of financial constraints.
                        Parts pillage time.
                        new KHC03.
                        Rosko Racing components, great experience with Shawn!
                        Really nice parts. Also put a slight bend on the fuel line.
                        New heater hoses.
                        Back on the road in 7 days, waiting on parts ate up a couple days. It runs awesome, no cel, idles great(F*ck a fast idle valve), 3rd and 4th gear vtec pulls sound amazing! I need to "loosen" the exhaust, replace the last of the P.s. rubber hoses, actually look into properly pinning a jumper harness for the throttle body MAP sensor, replace an axle, and get an alignment to straighten out the wheel.
                          Nice job
                            I like where this is going. Looks great man!!
                              Thanks!
                              Here's some new pictures with the fogs I got form losiracer2, I'll try to take more in the daylight.
                              HID Hi-beams are bright.
                              I did a poor job on the fog light holes, it'll remedy when I do the paint and body. I'm still laughing at lunacy of getting those 6 HID ballasts to fit in the bumper behind the fogs and bumper lens, but one of them may rub a hole in the wiper fluid reservoir, so that could suck for many different reasons...
                              Upside to not lowering a car is, ground clearance, yay. I do drive it like a truck and take speed bumps at 15, 20, and I'm always surprise that those runners are symmetrical. also the splash guard will be on soon.
