tell me what you think of this
    lol fine! What the hell were you thinking. Put those tails stock you'll look better but good try
    Originally posted by cb7pr View Post
    you like that? wow Thats just wrong, correct them taillights
    Car looks goog other than that.
      This thread is making me
      Welcome to the forum dude, hope to see more of you on here, sucks you can really feel much of a diff with the h trans weather its auto or not.
        ok guys so as of today i am pulling the engine to do all my seals and a new tranny had some complications but its cool new updated pics and i will be seeing you guys this summer heavy thanks for all the love i am loving the CB7
          Nice to see that someone else rocks the same rims ..
          Good lookin CB man ..
          Tomi
            Wow, crazy to see you taking the whole front end apart to pull the engine, then I remembered not everyone has lift access...lol
            keep up the good work guy, pretty clean car!
            '92 h22 CBMRT-->http://www.cb7tuner.com/vbb/showthread.php?t=158641
            UNICORNS=donkeys with plungers stuck to their faces...
              looks good dude great car to work with . keep up with the work and mabe get a h22 swap or a swap in genaral and you will be set. good luck
              life is as good as you make it. So forget what people say and do what makes you happy
                i just doing new seals on everything i dont want a h22 might push for a turbo f22a4 i dont know wen i get my engine correct i will figure it out
                  You got a nice cb yo. Nice to hear you keep it simple, good luck with it man..
                    u can make your A1 an A4 jus go get the exhaust manifold from an A4 that is the only difference between tha A1 and the A4 is tha exhaust manifold then the difference from them to an A6 is the Head has more aggressive CamShaft and Stiffer Valve Springs & have to go with tha ECU for tha A6 to get the proper fuel map for it So u can take a F22A1 and make it an F22A4 by adding tha Exhaust manifold from an A4. Then after doing so if want to make it an A6 after adding tha A4 exhaust manifold then add the A6 Head & ECU. Hopes this helps some it did me i had to do alot of research for this info after I got my car. I had an A4 in mine but crankshaft bearings were shot so i yanked it out and dropped an A1 in my CB7 and took tha Exhaust Manifold and tha Intake Manifold from my A4 and bolted it to tha A1 b4 I dropped it down into my CB7. Im going with tha A6 Head & ECU jus as soon as I find me ONE cheap laying around junkyard and gna rebuild tha head b4 i bolt it to my motor.
                      whats good bro how ur car is coming havent spoke to u in a min
