Haven't done much since its been super cold here lol but got the gauges in floor shifter in drive shaft in now only thing left is wiring and plumbing and modifying the stock crossmember or getting a after market one
TracieS : 1991 Chevrolet S10
Originally posted by '93CB7Ex View Postdid you even get it running yet?
Got the battery tray out moved the turbuo so it clears everything happy with postioning going the start building the hot side tomorrow and working on cutting up the passanger header and making a log manifold picked up some 15x10/8 centerline wheels going to run some mickey et streeet radial for some dig and roll action
little brother doing somhing
Harness came still need a fuel pump
LSx s10 - YouTube
Nice work. I picked up an 89 s10 blazer a couple of months ago. Your goal is low and fast mine is torque, 31" tires, and a moderate lift. Can you take a picture of your ground clearance?1993 SE Coupe MRT - 1992 LX Sedan MRT
93 Accord SE Bose Stereo MYTHS & FACTS - F22A* Power Plant Removal(UNDER CONSTRUCTION)
Originally posted by trickedaccord92 View PostSweet build bro! I just got an 83 1st gen s10 last month also. Won't be getting into the motor swap until tax time though. How much have you got invested in the motor swap so far? I should have around $5k to dump into mine come tax time.
Originally posted by wildBill83 View PostNice work. I picked up an 89 s10 blazer a couple of months ago. Your goal is low and fast mine is torque, 31" tires, and a moderate lift. Can you take a picture of your ground clearance?
