4x114.3 to 4x100 wheel adapters?
    ok so i have some 15" drags dr-31's just chillin it on my garage from when i took them off my ep3 i was wondering if it would be better to sell em or get me some wheel adapters to try fitting em on my cb , but i wanna know if anyone else has tried em before i get em and if theyve had any problems with em ?
    http://www.cb7tuner.com/vbb/showthread.php?t=157630
    From what i've heard you can do it but it's not very safe at all, and recommended not to use wheel adaptor's
    so i'm sure most of the site is going to tell you to sell the wheels and find a different set.
      Aren't EP3's 5 lug?
        Originally posted by itstatcb7kid707 View Post
        Aren't EP3's 5 lug?
        yupp and 4x100
          hell i'd do it for daily driving. your not gonna be drag racing or drifting, id say it would be fine
          as long as you have good lugs and all that..
          Ride: 2002 Lexus IS300
            Aren't EP3's 5 lug?
            nope there four :]
              ima just buy some that actually fit better
                Originally posted by Whieroman View Post
                nope there four :]
                the first couple years were, then they switched to 5 for 04-05
                  ummmmm.......... if you can get them use it i use to run porsche wheels on my vw MK2 gli .................and sayin that wheel adapter arent save its like says our hub over rotors aren't safe think about it
                    ummmmm.......... if you can get them use it i use to run porsche wheels on my vw MK2 gli .................and sayin that wheel adapter arent safe is like says our hub over rotors aren't safe think about it
                      I wouldn't take the risk on my car... what you do with yours is up to you. I just hope they don't cause a wheel to fall off.
                        i Wouldn't Take The Risk On My Car... What You Do With Yours Is Up To You. I Just Hope They Don't Cause A Wheel To Fall Off.
                        x2...
                          x2...
                          i guess to each it own but ur thoughts about wheel adapters are wrong if you havent ever used adapters or spacers then i guess that you really cant speak i trust them 100% if you tighten them properly you will never have an issue saying anything else about them will be like saying that the factory set up on a cb7 is unsafe since we have a hub over rotor or saying that wheels or rims aside from the factory ones arent safe that they will fall off so to each its own i myself will be puttin spacer on my cb7 i hate the way the wheels sit so far in the fender i like wen things line up
                            I know there are mfg's that make custom spacers and wheel adapters. I have used this style in the past, but they can cost you $100 a corner
