ENGINE:
JDM H22a 96 OBD2 2/13
P2T4 manual tranny 8/13
Exedy prelude clutch and stock flywheel 8/13
Acura OEM RDX 410 injectors 02/14
Beck Arnley Fuel Filter 3/14
OBD2 dizzy rewired to OBD1 plugs
P72 chipped ECU 10/14
Hondata S300 2/13
Hondata CPR 3/14
Honda coils x4 Denso 673-2302 3/14
NGK ZFR6FIX-11 3/14
Innovative LC-1 wideband O2 4/13
KS manual Tensioner 2/13
OEM honda timing belt, BS belt 2/13
PLM Replica header 7/13
Magnaflow 2.5 metal core cat 4/13
Vibrant 1141 resonator 2/14
Apexi WS2 catback 2/13
Ebay SRI with K&N filter Wrapped with thermo tec heat barrier
New Starter, battery 12/12
Rear main seal Replaced 02/14
New Lifetime radiator 3/14
2 Spal fans 30102029 with spal realy 3/14
Retro fitted AC by me, Newly rebuilt compressor, new exp valve, new drier: Blows 44
Works even better after the spal fan upgrade. I have a Par Flow condenser but not sure I need to change it out. That will be a major project.
EXTERIOR:
S2000 antenna
Yakima rack
93 SE front bumper with lip
Painted in 2000 stock seattle silver
Retro fit USDM blackhoused morimoto H1 with graphite shrouds
OEM flushmount Painted to match
Depo sidemarkers
INTERIOR:
Katzkin Grey coupe leather
Black dash
CD5 grey Floor mats
Original Maroon int converted to grey/black SEM
Carpet dyed black
Map light with sunglasses holder
LED Cluster Blue
Black armrest
SUSPENSION/WHEELS
93SE wheels polished by me
Michelin pilot exalto 195/60/15 9/13
Ground Control, Koni yellow middle perch 12/09
Ingalls front anchor bolt kit 1/13
Shimmed in the rear
MOOG UCA, Lower BJ front 7/12
MOOG UCA rear 7/12
CUSCO strut bar 3/13
Ex cross member: vigor rear sway bar 2/13
Energy Suspension Master kit 11//19/13
Reman steering rack 8/08
New inner and outer tie rods MOOG 1/13
Vigor rotors beck/arnley 3/13
97 TL Calipers 15vn 3/13
Hawk HPS pads 3/13
AUDIO/ELECTRONIC
3ch alarm with trunk pop (My favorite mod)
Pioneer avh-5500
Alpine pdx-f4 4 channel amp
Alpine M500 mono amp
Alpine type R 8 in sealed box
infinity kappa 6.5 components up front
Infinity refernce 6x9 in rear
4ga knu wire to dist block
Front speaker wire 10g rear 14ga
Big 3 with 4ga wire
HO alt 180 amps new 4ga alt power wire
MLV installed in doors and on the floor
FUTURE PLANS:
Finish the CL wheels
I’ve been a member on here for a while and never had a MRT so here goes.
This car is my daily driver and has been very reliable.
I’m the second owner of this car, acquired in 1999 Until recently it never had any engine work. And probably could have gone another year or two.
I noticed a crack in my a1 exhaust manifold, while changing the manifold I noticed oil on one of the exhaust valves so. I figured I would just replace the Head and upgrade some stuff while I’m at it. Car has more power and drives better but I think it would have been easier to send money to Hmotors and get an H22.
The car has somewhere between 490,000 and 515,000 miles. I lost track between the 3 clusters I’ve had but it’s a lot. Everybody I know says they wouldn’t recognize me if I had another car.
Anyway nothing special
Steve
