Old 04-09-2011, 12:17 AM   #1
johnny12
CB7tuner Member
johnny12 is cool... so far.
1991 accord motor help
I need to no how to set the tdc in my motor can head everything I took the head and cam and timing off and just found out you had to set it so what do I need to do now
johnny12 is offline   Reply With Quote
Old 04-09-2011, 12:57 AM   #2
MrSpeedy
CB7tuner Member
MrSpeedy is cool... so far.
Quote:
Put everything back (not the timing belt) there are markings on the camshaft pulley "up". And on the crankshaft and arrow that you should line also up with the camshaft. Also you need to line up the balancer shaft and it's got an red arrow that should line with the marking on the block. Then just put the timing belt on and check that markings are lined as mentioned. I think there is sticky for this if you need a more detailed info.
Edit: http://www.cb7tuner.com/vbb/showthread.php?t=55332
MrSpeedy is offline   Reply With Quote
Old 04-09-2011, 01:25 AM   #3
johnny12
CB7tuner Member
So how do I set the cam or do I put the timing belt pully on and set the markings and what about the pistsions just leave them in the same spot or what just need more details bro
Old 04-10-2011, 10:56 AM   #4
MrSpeedy
CB7tuner Member
The camshaft pulley will only go in one way (on the camshaft). So you can't set that wrong. And when you turn the crankshaft your pistons will move. So when you line the markings then everything should be correct. I gotta ask, that how did you end up in this situation?! I mean, I think you should've first know the theory of what you are doing, before really doing it. Did you read the link I posted?
Tags
1991 , accord , f22a4 , motor
