91 accord what can i do fix the car from flooding
Spark plugs wet
Originally posted by roland92ha View Post91 accord what can i do fix the car from flooding
Check for spark.MRT
Originally posted by Tippey764I think driving your car naked will cause the engine to overheatOriginally posted by deevergotesneaky motherfucker
Gas wet or oil wet?**Blk Housed Slut Crew Member #1**
Originally posted by F20A CB7 View PostGas wet or oil wet?
If its from oil, you will need to change you sparkplug upper seals. They usually come standard in a valve cover gasket set, so you could do all of it at once, pretty simple standard job.
Worst that can happen is that it is the lower seals (my car has those messed up) but i just clean my plugs off frequently and I dont have issues since I plan on swapping heads anyways.
If im not mistaken, to change the lower ones you have to remove the head. Dont quote me on that as Im not sure and probably a member with more info can help you with that
If im not mistaken, to change the lower ones you have to remove the head. Dont quote me on that as Im not sure and probably a member with more info can help you with thatMRT
^ I hate adjusting the valves. So easy yet I have trouble.**Blk Housed Slut Crew Member #1**
Originally posted by roland92ha View Post91 accord what can i do fix the car from floodingOriginally posted by deevergoteThat is exactly why pork chops don't taste like chocolate!
