Go Back   CB7Tuner Forums > Site Features > DIYs > Engine DIYs
Thread Tools Rating: Thread Rating: 2 votes, 5.00 average. Display Modes
Old 04-03-2014, 05:29 PM   #1
DCB7
CB7tuner Member
DCB7 is cool... so far.
ENG: DIY slide hammer (for EGR port cleaning)
I'm not sure if this deserves to be in the DIY section, but might be helpful for some. It worked for me. I've read that cleaning these ports should drastically improve the performance of the stock engine in our cars.
There's already a DIY on EGR port cleaning here:
http://www.cb7tuner.com/vbb/showthread.php?t=2495
and other detail write ups across the web (like on FLaccords)
but no one at the stores I went to knew what a slide hammer was. Even the guy at autozone didn't know it was on the tool rental list. But theirs was huge!
Then I found this:
http://www.preludepower.com/forums/s...d.php?t=275440
which still requires you to tap the holes to get the rod in. I don't have a tap&dye set so I did this:
Tools
3" sheet metal screw
12"x1.25" steel pipe + 1 cap
pair of pliers
screwdriver
drill and bit
First I drilled a hole in the cap, big enough for the screw to go through but not the head, like this:
I used a screw as a center punch, then drilled the hole (slightly smaller in diameter than the screw)
Then, with the screw through the cap, I screwed the 3" screw into the plug (deep enough not to rip out):
Then attached the pipe:
Then with the cap resting on the IM, yank it up real hard. Two, maybe one good pull, and it's out. Surprised me how easy it came out with this contraption. Even the side plug was a breeze.
Then I removed the pipe from the cap, held the plug with the pliers (not too tight to damage it, because I'm reusing them) and removed the screw with the screwdriver.
All the passages were fully clogged. Had to screw into the holes at the bottom of the EGR passages to break the build up free. After cleaning I epoxied the holes in the plugs and knocked them back in.
I then returned the pipe to Home Depot and got my $10 back because I had no further use for it (the cap was $4) but I drilled a hole in it, so....
Hope this is useful for someone.
__________________
DCB7 is offline   Reply With Quote
Old 04-03-2014, 07:00 PM   #2
cb7 calling
CB7tuner Member
cb7 calling is cool... so far.
That is perfect. I like how the only thing breakable is a 1 cent screw. If you add a larger diameter pipe over that one and a cap on the other end for the large pipe to smack you have a slide hammer fit for dent pulling. Again indestructible.
You are really on to something. Sizes are unlimited.
__________________
......father in law has it back again. Time to shine
cb7 calling is offline   Reply With Quote
Old 04-03-2014, 08:24 PM   #3
DCB7
CB7tuner Member
Yeah, I got you. Like say put a inch and a half pipe over the 12" pipe. When I'm ready to do some body work ill remember that
__________________
Old 04-03-2014, 08:33 PM   #4
bobbycos
Contributing Member
bobbycos seems to have made some friends! bobbycos seems to have made some friends!
Send a message via AIM to bobbycos
sweet writeup
bobbycos is offline   Reply With Quote
Old 04-03-2014, 11:13 PM   #5
DCB7
CB7tuner Member
Thanks
__________________
Old 04-05-2014, 03:31 PM   #6
P5ylance
CB7tuner Member
P5ylance is someone to admire P5ylance is someone to admire P5ylance is someone to admire
thank you SO MUCH for this!!!
__________________
P5ylance is offline   Reply With Quote
Old 04-05-2014, 08:10 PM   #7
DCB7
CB7tuner Member
No problem
Glad it was helpful
__________________
Old 04-06-2014, 03:52 PM   #8
xkjnboix
CB7tuner Member
xkjnboix seems to have made some friends!
Send a message via AIM to xkjnboix
Nice ingenuity
H23 IM is just welded shut solid aluminum
__________________
frostwhite225@gmail.com =VENMO
http://www.youtube.com/watch?v=NOB38zJu66o
[color="Magenta"]
xkjnboix is offline   Reply With Quote
Old 01-22-2018, 06:46 PM   #9
cb7 calling
CB7tuner Member
Now I need these pics cause I'm about the clean the ports on an f23.
__________________
Old 01-22-2018, 07:47 PM   #10
Grumpys93
Contributing Member
You don't need to create a slide hammer for this, simply screwing in a self tapping screw and then taking the back end of the hammer to pull the screw out.
__________________
~Nick~
Tags
egr , ports , slide hammer
