Old 07-18-2008, 04:22 AM   #1
H22Artman
H22Artman is cool... so far.
Just picked up my 1992 CB7....
it came with a h22a, auto LSD tranny and fully adjustable suspension.
it needs a bit of work to make her run smooth.
my questions are:
what kind of power should i expect when its running right?
where will my shift points be?
are there common problems with this swap that i should be aware of?
any other help and advice for a noob swapper would be tight.
i can wrench a stock one in my sleep but i have no clue as to what to expect when it comes to engine swaps.
thanks a mil guys.
my CB will appreciate any help.
H22Artman is offline   Reply With Quote
Old 07-18-2008, 07:54 AM   #2
GUA-D'zCb-7
GUA-D'zCb-7 may have said something they shouldn't have...
piks
my whipp
GUA-D'zCb-7 is offline   Reply With Quote
Old 07-18-2008, 09:02 AM   #3
customchord
customchord is cool... so far.
Are you swapping the car or is the motor already in. As for your questions
1 I would say you could expect around 150 to 160 hp to the wheels if its stock and since it is a auto.
2 Your shift points should be somewhat high(above7k RPM)
3 As for a Auto H22 swap in a cb is pretty much like a direct bolt in swap. No major modifications just some basic electrical...you can find all the information on this swap somewhere on this site. Probably the swaps section just search.
-1991 Honda Accord LX H22a-
customchord is offline   Reply With Quote
Old 07-18-2008, 12:50 PM   #4
H22Artman
Everything is installed:
i bought it only running on 3 cyls. i expected some work for the low low price i paid for it (1500). its only holding 30lbs in the number one cyl at the moment. gonna check valve clearance, and then run a leak down. see where we go from here....
any suspicions on the extent of the damage is greatly appreciated.
thanks guys.
http://api.photoshop.com/home_e94c4f...f1e61478937bb3
atomatic , h22 , h22a , lsd , swap
