Originally posted by ShotgunFacelift
View Post
Most bang for your buck! whats in your trunk?
I was thinking along those same lines. I found that the recess that the trunk sits in has gotten some cancer around where the trunk arms are and the PO cleverly covered up the spots with black duct tape and I didn't even see it until earlier today. I don't know if there is an easy fix for that but at least I found the problem...
lets just be clear, Im only posting this because you asked what we are running....not saying that you need to go crazy like this, so here I go....
KENWOOD KDCX997
JL AUDIO XD700/5 (ENTIRE FRONT STAGE)
HERTZ ESK165 (2 CHANNELS)
PYLE PRO DRYVER PDS772 HORNS W/ JBL SELENIUM THROATS (2 CHANNELS)
5TH CHANNEL- CROSSFIRE XSM8 MIDBASS DRIVER (ENCLOSURE IN PASS. FRT FLOOR)
JLA AUDIO XD600/1
3 JL AUDIO 12W1V2-4OHM
IN 4TH ORDER BANDPASS THROUGH REAR DECK...3FT SEALED/4.5 FT PORTED WITH 115 SQ IN PORT BY 9 LONG.
HERTZ DSK165 OF OFF KDCX997 DECK POWER IN REAR SIDE PANELS FOR REAR FILL
all MESA branded wiring.....stock alternator and Stinger SPV69C battery
METERED 144 DB FROM 30-40HZ
and it is still crystal clear for everyday use, mainly due to the horns and midbass driver.
Originally posted by ShotgunFacelift View PostA little bit of silicone and my trunk no longer leaks. Put my (2) 10s in a box, mounted my amp, and ran all the wires. Turns out my amp is completely F'd so I'm still rocking out in all treble.
Originally posted by SterlingVMoses View PostYou can always get a cheap amp from Wal-Mart for your setup..won't hurt a bit.
In other news, the trunk leak is not fixed as I believed it to be. On to the taillight seals next...
I personally have a thing for Sundown. I have one single SA10-d4 in a 3 cu.ft box tuned to 35hz, running off a Power Acoustik reaper 2200 And its only running about 700w @4 ohms. People always assume i have two twelves, or a 15, and i love the reactions when i pop the trunk. Noone ever expects a low power setup to be so loud. For the rest of the car i have an old mtx road thunder 250w amp powering 4 decent pioneer speakers i picked up at Walmart for about 70 bucks a pair. Now that im starting a new build, Ill be switching up the stereo setup, just havent really decided what to go with yet. Definitely getting a second sa10-d4 for sure. Call me a fanboy, But my subs been going for about two and a half years now, and i bought it used from someone who had it, along with 9 others running on 2200rms Each. The quality speaks for itself
