Need help with clutch
    I bleed my clutch on my 1990 accord. But the clutch still wouldn't work.
    The clutch is still on the floor and won't pop back up.
    Any help? Suggestion what to do next?
    All I can say is pull the pedal back up and continue bleeding. If you replaced the clutch master cylinder, did you bench bleed it before you installed it? The clutch is a royal pain to bleed!
      Call a friend for help. It's MUCH easier with two people.
      A vacuum pump also works nicely
      YouTube Clicky!!
        also did you adjust the master cylinder rod correctly?
          I just had this same issue and I ended up having to use a brake bleeder kit and it worked great!
            i havent install a clutch master cylinder. ill probably use a brake bleeder kit too and see how it goes.
