Hey guys I'm having issues with my Accord. I am having issues with my electrical system not wanting to completely charge everything, what I mean is running w/o lights on I have no issues but when I turn on the blower fans or the lights(headlights/running lights or brake lights) my motor get hot. When I am stopped at a light i have to use the emergency brake to keep my motor cool as it doesn't use my taillights, I have replaced the fuse box twice but i am guessing that both fuse boxes ELD has failed. I have also tested the alternator at Autozone and they said that the regulator has failed would the ELD give that response for their system or is it at the alternator? Any help or suggestions would be greatly appreciated.
ELD Problem
I believe the ELD is primarily there to detect electrical load to help the ECM maintain an appropriate idle speed - I don't see how a malfunctioning ELD would cause the engine to overheat. If your car is overheating, first make sure there is enough coolant in the system, check that your fans are operating correctly, check (or go ahead and change it) the thermostat.90 LX 4dr 5 spd 396,014 (sold 1/1/2022) - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
I think your car isn't overheating, I think you have a bad ground that's making your temperature gauge go up, if electrical components sre making it overheat, that would be my guess. Check your grounds !sold! But here's my build thread for those interested.
http://www.cb7tuner.com/vbb/showthread.php?t=206864
Originally posted by lbus9168 View PostI think your car isn't overheating, I think you have a bad ground that's making your temperature gauge go up, if electrical components sre making it overheat, that would be my guess. Check your grounds !
So it's okay now?sold! But here's my build thread for those interested.
Originally posted by indoplasm View PostI did notice today on my way home that the idle dropped to about 500 rpm and started to get warm maybe in the 190/200 range, but otherwise it didn't act weird today.90 LX 4dr 5 spd 396,014 (sold 1/1/2022) - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
Originally posted by fleetw00d View PostWhen you say 500, you mean all the way down to the large mark just above zero? That first mark above zero is actually 500, normal idle speed should be right around 750.
Originally posted by indoplasm View PostIt was idling around around the about 3/4 of the way to the one on my rpm gauge and dropped idle to about half of the 1 and 0
Check your negative battery cable. A bad one can overwork the alternator.Originally posted by Junior SmurffNevermind guys, google search works wonders!
Well update guys, I have walked to Autozone to get a fresh alternator from them put it in and not much change... 4G as to what you said where the ground bolts to the motor is a little split apart. What i mean is that instead of it being tightly wound like a new one from honda is it is more fanned out
Originally posted by shaggyky84 View Postthe first one, about 3/4 of the way to 1000rpm is approximately the correct place for it to idle. the correct idle speed is 750rpm. like was said previously, the first thick white mark is 500rpm then goes up to 1000rpm in 100rpm increments. if it dropped to halfway that sounds like it is possibly a little low, hard to tell without seeing it
Just double check all your wiring, the idle seems fine.sold! But here's my build thread for those interested.
