just had a question. i know i have 2 let it sit for 24 hrs so it can dry up good but i dont have 24 hrs cuz its my dd so what can i do 2 speed things up
ENG: DIY Solid Polyurethane Engine Mounts- Performance & Repair
warm it up with a lamp, hair dryer, heat gun, etc. maybe an oven, but be careful. Warm it up progressively and stay in the 250 degree range.
The H22 Sleeper Sedan, updated 8/14
After 4 months down...It's back! and tucked.
Need a Swap or some work done in the DC/MD/VA/WV area?
PM me and get it done right!
I guess it doesn't really matter even if it were to get torn up if you're going to fix it anyway.
The front mount is the only one I have done and now after more than a year it still looks just like the day I filled it.
dont know if this was asked.
how did it take for it to dry.**Blk Housed Slut Crew Member #1**
can i use roofing polyurethane polymer to do this??
its like 9 bucks for a big ass one..but it says its for roofing and contains polyurethane polymer..anyone try it??
Rush
Originally posted by DarkcloudBought 3 things, 1 that goes boom,1 that shades and 1 to go fasrer
Originally posted by bmxicansdso you got a boombox, sunglasses and rosettta stone?
So I filled a new front motor mount today with 3M window weld, but I am still a little unsure on how long it takes to cure. Does anyone know how you can determine that it is fully cured? I know Lucid said 24 hours in his first post, but now I am a little worried about the two weeks comment. Just thought I would revive this thread for some more clarification. Thanks.
It was only "bad" at idle. Note though I had my balance shaft and no A/C. Either one will make shit worse at idle. It was pretty much good above 900 RPM though.
Originally posted by lordojaim with you on that one bro! aint nothing beat free food and drinks any day of the week, even if its at a funeral
A different product. 2 part Polyurethene 60a.
http://www.ebay.co.uk/sch/i.html?_od...+500g&_sacat=0
You can choose your stiffness. Drys in 1hr. Gets thick and treacle like in 5mins. It self levels.
Both sides looked like this. Ive freshed up the mount since before I installed it and sprayed over it in black and paint adheres to the rubber no problem.
