Thread Tools Rating: Thread Rating: 9 votes, 4.56 average. Display Modes
Old 06-08-2019, 11:27 PM   #561
af_1132
CB7tuner Member
af_1132 is cool... so far.
Send a message via Skype™ to af_1132
I see that service manual in there! I am so glad I have one, I just wished mine looked as good as yours.
I just read through about your 180 out timing troubles. I'm sorry you're having to go through that right now.
Those readings on the AFR gauge confuzzle me. 16.8 at WOT is downright dangerously lean, and still leaner than mine was running if I were to hold it a 2k. It is also the AFR cap reading if you are using the D14 signal, which runs from 0-3.x volts The fact that the AFRs didn't change makes me think it is not hooked up correctly. Did you pin the ECU wire for the wideband to D14 on the ECU?
__________________
*** Think of others before thinking of yourself. ***
MRT
FS Thread
15.10 @ 90.42mph
af_1132 is offline   Reply With Quote
Old 06-09-2019, 07:17 AM   #562
Grumpys93
Contributing Member
No I did d10 and clipped the two resistors r138 and r136 so it sees the full 5 volts. Followed phearables method.
__________________
~Nick~
Old 06-10-2019, 04:00 AM   #563
Raf99
Gold Member
Raf99 is very helpful Raf99 is very helpful
so what are you going to do?
Old 06-10-2019, 11:12 AM   #564
af_1132
CB7tuner Member
I also want to double check that you calibrated the wideband. On my Innovate model, if I remember correctly, I had to turn the ignition on and have the wideband open to the air for 30 seconds or so.
__________________
MRT
FS Thread
15.10 @ 90.42mph
Old 06-10-2019, 02:23 PM   #565
Grumpys93
Contributing Member
So some good news, decided to triple check my timing and I was off by one tooth, literally one tooth, compression is now 190/185/180/190 and it starts. Still doesn't run without me holding the throttle slightly open. Also kinda sounds like its running on 3 cylinders. Checked spark at all 4 and all 4 are sparking. They all smell like gas, and the AF is holding around 11-12 at 1k. So I sent a datalog to blake and he is going to take a look and refine it.
Also I am running AEM X-series wideband and it doesn't say it needs any calibration, but I will triple check that.
__________________
~Nick~
Old 06-10-2019, 04:36 PM   #566
Raf99
Gold Member
Well, great news! When's the appointment with Blake?
Old 06-10-2019, 05:11 PM   #567
af_1132
CB7tuner Member
Hmm, what is your fuel pressure and what do you have set at the injector duty cycle?
__________________
MRT
FS Thread
15.10 @ 90.42mph
Old 06-10-2019, 07:02 PM   #568
Grumpys93
Contributing Member
Quote:
Quote:
I sent Blake a datalog today to work out the idle issue since the car wont idle on its own. Once we get the idle issue figured out well set an appointment.
My fuel pressure is 38psi and Ill have to look to see what the duty cycle is. Im still trying to learn my way around S300.
__________________
~Nick~
