Just Recently My H22 Been Idling At 1500 After Its Warmed Up Any Suggestions On How To Fix This Shit Its Annoying And I Have No Check Engine Light And No Vacuum Leaks
H22 Idle At 1500rpm
Originally posted by bk92accordex View PostJust Recently My H22 Been Idling At 1500 After Its Warmed Up Any Suggestions On How To Fix This Shit Its Annoying And I Have No Check Engine Light And No Vacuum Leaks
Originally posted by bk92accordex View PostKeah I Tried That To I Got That Shit Screwed All The Way To Ur Cant No More Lol
Throttle cable might be too tight?..How Do You Keep Typing Like This Btw?
*Needs*
-New shocks
-Struts
-Drop
-Cleaning
-New Tires/Wheels
-New Window Tint
-Alot more lovin'
My Panda:http://www.cb7tuner.com/vbb/showthre...ghlight=Djmoua
You should double check and triple check for vacuum leaks. Also, you may wish to take off the plastic portion of the intake and check to see if the throttle plate is slightly open with your foot off the pedal. Have you done any modifications or repairs recently?
Originally posted by Djmoua View PostThrottle cable might be too tight?..How Do You Keep Typing Like This Btw?
"The fault-finder will find faults even in paradise. Love your life, poor as it is. You may perhaps have some pleasant, thrilling, glorious hours, even in a poorhouse."-Henry David Thoreau
