6.5" won't fit my door, wow!
    I red the owners and repair manual and even came on the forum to see recommendations on speakers. I bought a pair of Alpine's in 6.5" and they don't fit, rofl. My bad I didn't flip the vehicle's OEM adapter to see it's only 6".
    Now - how can I fit those 6,5" into the door? Any futher drilling required? Adapters like 6.5" to 6" don't exist here, and I'm not skilled with any wood work, neither do I own any tools required for this job. Can anyone help me out?
    Thanks.
    ditch the plastic basket, use a foam gasket, or MDF ring and some sheet metal screws. if theyre type-r's theyll be too deep and you will need a 11 or 12mm thick MDF ring, but then the speaker surround touches the backside of the grill on the door card, theyre a tight fit. Other brands like run of the mill Pioneers just fit right in with a gasket and screws.
      were you able to fix it?
        For anyone reading this and wondering if there has been documented fitment of 6.5" door speakers, this video https://www.youtube.com/watch?v=LaAkLT-hBrw shows how it is done.
          You can get speaker adapter rings for that. I have Skar 6.5s in the front doors with aftermarket speaker rings I got from sonicelectronix.com. The Skar are slightly oversized so they're not direct drop ins for the rear. I have to modify the rear deck for the other 6.5s to fit
            Use these for the front doors and you're straight
