Will the cluster work? will the door indicator light work the same?
Will 4DR or 5DR Cluster work on 2DR EX
Although most clusters look the same, there are minute differences that prevent one from swapping any cluster over. Generally, you need to find a cluster from a donor Accord that's very similar to your own.
Like Leung said, there are two manufacturers. Nippon Seiki (NS) and Nippon Denso (Denso). Look at the speedometer. The manufacturer is printed on the bottom of the speedo.
All coupes have NS clusters. Some sedans exported from Japan have Denso clusters - all SE models, for example.
There are issues with year compatibilities.
Once you figure out which manufacturer produced your cluster, look at model year and trim.
90-91 DXs are interchangeable with each other (dependent on manufacturer).
90-91 LXs and EXs are interchangeable with each other (dependent on manufacturer).
91 SE sedans must be swapped with another 91 SE sedan.
92-93 DXs are interchangeable with each other.
92-93 LXs are interchangeable with each other.
92-93 EXs are interchangeable with each other (dependent on manufacturer).
93 SE sedans must be swapped with another 93 SE sedan.
93 SE coupes are interchangeable with any 92 or 93 SE or EX coupe.My pictures/photos will return soon...
Originally posted by XcluziveAZN View PostI have 93 EX Coupe. so i have to check the connector right? or can i just get any 92-93 cluster
what about the door indicator?
Most coupes have NS clusters.
EDIT: Danny beat me to it! Ah well, the info below is relevant still.
If you can't find one, you can use a NS cluster from a 92 or 93 EX sedan or wagon.
The door ajar indicators won't light up because there's no rear door indicator wiring in your coupe.
Bottom line, it has to be a NS cluster. 92 or 93 EX coupe or 93 SE coupe is best.
If you don't get one that meets your required criteria, even though the plugs might match up, the pin location on the cluster might be different. This might cause strange things to occur, like so:
